frenchyd
frenchyd PowerDork
8/21/20 12:26 p.m.
In reply to lnlogauge :
Don't try to pry ball joints out. Use opposing hammers. Pop them out like a pimple. Remove the nut and washer and holding one sledge hammer firmly dead center of the taper against the lower A arm use the other sledge hammer to hit it hard right at the center of the lower A arm. The taper on the ball joint will cause it to spit out like a pimple
Easy peasy. But no timid taps. Really swing hard.
Donebrokeit
Donebrokeit UltraDork
8/21/20 12:29 p.m.
spitfirebill said:
In reply to Donebrokeit :
time to ask for a raise.
Waiting for a reply.
So what is the reason some shops are doing really well and others are sucking wind?
Maybe related to this: https://www.washingtonpost.com/politics/2020/08/19/finance-202-economists-talking-up-k-shaped-recovery-stocks-surge-inequality-widens/
8/21/20 12:45 p.m.
In reply to CrustyRedXpress (Forum Supporter) :
It's definitely a local thing here.  All the shops within one or two miles are deadzo.  Busy elsewhere.
8/21/20 12:59 p.m.
The phone rang twice today so far and both times it was telemarketers.  Did one oil change on a new car, a safety inspection on a car they have decided they will scrap, a 10 minute repair on a failed emissions, and brake pads under warranty on a Volt.
I'm so bored that I am trying to decide if the Volt is a hatchback or a liftback.  It LOOKS like a liftback, but the back door doesn't close against the rear seatbacks, so the cargo area is never separate from the cabin.
John Welsh (Moderate Supporter)
John Welsh (Moderate Supporter) Mod Squad
8/21/20 1:09 p.m.
In reply to Pete. (l33t FS) :
I wish you were closer. I have 4 cars needing oil changes. Another with a noisy wheel bearing and another that seems to need rear brake pads.
8/21/20 1:15 p.m.
In reply to John Welsh (Moderate Supporter) :
Oh, when we do get cars in, they decline services.  This week there have been a lot that frankly should have been scrapped, but the rest have been wait and see.
docwyte
docwyte UberDork
8/21/20 1:17 p.m.
In reply to z31maniac :
The problem is the Indy shops labor rate isn't that much less than the dealer.  So you're not really saving that much money and it's a PITA to deal with the Indy as they don't have loaner cars like the dealer.
I do most of my own work, so the cars really only go in for warranty stuff, which is dealer covered.  I have one really good VW/Audi Indy that I use for jobs I don't want to do and I just deal with the inconvenience of no loaner car because I really, really like them.
z31maniac
z31maniac MegaDork
8/21/20 2:18 p.m.
Regarding labor rates, that may be true in your area but it isn't in mine. THE shop to take your BMW/Merc/Ferrari/etc is $105/hr labor. The BMW dealer is $155/hr. I think the book time on replacing the valve cover gasket on my 135i was 6 hours? So, for me, a loaner car wasn't worth $300 to make some small adjustments to my schedule and use an Uber one-time. Drive car to shop, Uber home, have girlfriend drop me off the next morning to pick up.
But I also understand convenience is worth more/less to different people in different situations.
When I did take it in for the airbag recall though, I did really enjoy the loaded X5 I got as a loaner. Until I got online and did a guesstimate on the costs based on what I saw........and thought "Who in hell would pay $65k for this and it doesn't even have a V8?"
8/21/20 2:28 p.m.
Dealer rates here are $160-200 per hour...
chada75
chada75 Reader
8/21/20 4:54 p.m.
The problem with Shops around here is that when they want to hire a tech and you have experience, You get there and they don't want to hire you. So any shop that are hurting for business shows a sorry management shop.
Dave M (Forum Supporter)
Dave M (Forum Supporter) HalfDork
8/21/20 5:39 p.m.
Bingo! If you WFH you're doing fine, most likely, and you're driving way less. Hence the crickets at the shops in Santa Barbara.
Meanwhile if you have a job that you need to get to, you need that car. And you're probably making less money, so you're keeping the old car on the road longer.
ysal4JUUHFMff7lICg1leu78YvryRInchq86AJ79iUEf2hQBoMFjj3CMAVKeKKqF
