Mazdax605
Mazdax605 UltraDork
4/4/17 1:46 p.m.
Hey guys,
I found two gallons of Rotella-T 15W40 today. They are brand new, un-opened, but from March 10th 2009. Are they still good, or would you not risk it?
Bobzilla
Bobzilla UltimaDork
4/4/17 1:50 p.m.
depends. Exposed to UV/Sunlight? If stored indoors, out of light, at a consistent temp it should be good but I imagine the additives may have settled out and may require shaking/mixing.
Blaise
Blaise New Reader
4/4/17 1:51 p.m.
Doesn't go bad.. its sealed up! Go forth and use.
Mike
Mike GRM+ Memberand SuperDork
4/4/17 1:53 p.m.
If it turns back into dinosaur, do not use.
Bobzilla
Bobzilla UltimaDork
4/4/17 2:04 p.m.
Mike wrote: If it turns back into dinosaur, do not use.
This is good advice.
BrokenYugo
BrokenYugo MegaDork
4/4/17 2:14 p.m.
Flip the bottle over and shake it to death, proceed as normal.
APEowner
APEowner GRM+ Memberand Reader
4/4/17 2:23 p.m.
I'd use it.
4/4/17 2:31 p.m.
Still good, go for it.
Streetwiseguy UltimaDork
4/4/17 2:36 p.m.
As long as it still meets the standards for the engine, go nuts.
Cactus
Cactus Reader
4/4/17 2:53 p.m.
I'd use it, I'd probably even forget to shake it. A lab (probably Blackstone but I don't remember for sure) bought a bunch of ancient oil cans off eBay, the kind that you need a can opener to get into, and did analysis on them. Some weren't too bad by modern standards. I think one of them was a caster base.
mtn
mtn MegaDork
4/4/17 5:10 p.m.
The one thing I'll say is to be careful which car you use it in. 99% of vehicles I wouldn't worry about it and throw it in there, but a Boxster I might not.
Mazdax605
Mazdax605 UltraDork
4/5/17 8:53 a.m.
How about using it in a 28 year old Japanese diesel minivan?
The0retical
The0retical Dork
4/5/17 9:10 a.m.
TenToeTurbo
TenToeTurbo Dork
4/5/17 9:54 a.m.
Mazdax605 wrote: two gallons of Rotella-T 15W40
That's what I use in my SV650. You have 2-2/3 SV650 oil changes right there.
Robbie
Robbie GRM+ Memberand UberDork
4/5/17 10:15 a.m.
The0retical wrote:
Ahhh, the old 'radiator stop leak in the oil' trick.
njo4ACFk85Axz1oJPWLnfm3wNzxwCH3wMftgWuGha6YnbEamTSvlIqLxgecduNQw
