jr10cross
jr10cross Reader
10/28/17 8:09 a.m.
So I spray can plastidipped my whole car to enjoy a good driving season. I picked the car up extremely cheap but wasn't  ready to drop the dough on a solid paint job. Now its time to do her right, but is canned plastidip easy to remove? Tell me what you think:
http:// https://youtu.be/GAU6-uasBts
<iframe width="330" height="186" src="https://www.youtube.com/embed/GAU6-uasBts" frameborder="0" gesture="media" allowfullscreen></iframe>
10/28/17 8:18 a.m.
How many coats did you do? If you only did 1 coat, your life is gonna suck. If you did the recommended 3-4, it will peal off in nice big sheets.
jr10cross
jr10cross Reader
10/28/17 9:14 a.m.
In reply to Appleseed :
It's hard to estimate with the cans but i think a good 4 coats. It did pull up in sheets. I'm wondering what the fus is about. I think this is a really underrated solution.
Trackmouse
Trackmouse SuperDork
10/28/17 9:54 a.m.
I’ve been saying that for years. It lasts too. My car has built up more than 4
layers over the years. I usually just wash it and touch up the areas that got rock scuffs or stains. I use the flat black though as a protector of the lower body paint on dirt roads.
10/28/17 11:10 a.m.
Even if you have a good number of coats, it can get dry, crusty and hard to remove over time. To prevent this you need to add a coat every 2 years or so.
jr10cross
jr10cross Reader
10/28/17 12:42 p.m.
In reply to GameboyRMH :
I like add 2 coats a year!
10/29/17 1:38 a.m.
Ha! Funny, because on the Murdercycle, I'd never clean the dip, or remove it for a color change, just add another layer.
pointofdeparture
10/29/17 8:56 a.m.
I had a really bad experience with it after buying a car someone else dipped, where it took me about 10 hours across two days with a pressure washer and every solvent known to humanity to get it all off. It was a nightmare!
I know that one was probably not applied correctly or maintained well but it has definitely made me hesitant towards Plastidip as a result.
Iusedtobefast
Iusedtobefast Reader
10/29/17 7:17 p.m.
How does Plastidip do submerged? I have a couple 25lbs weights I use on a pool ladder and after painting and wrapping them in plastic every year, I was wondering if this would be a better option
Huckleberry Snorklewacker
Huckleberry Snorklewacker MegaDork
10/29/17 7:40 p.m.
Does anyone know if it can be used to make a peel-off super hero suit for Halloween? Will it harm the liver or genitals?
Asking for a friend.
G_Body_Man
G_Body_Man SuperDork
10/29/17 8:33 p.m.
It's safer for your hootus than bedliner.
parker
parker Reader
10/29/17 9:53 p.m.
It turns into a nightmare on removal
Run_Away
Run_Away GRM+ Memberand HalfDork
10/29/17 10:05 p.m.
In reply to parker :
Not if you get a really close shave first
grover
grover GRM+ Memberand HalfDork
6/14/18 11:11 p.m.
heck, this stuff will give you that full Brazilian look you've been dreaming of.
6/14/18 11:19 p.m.
Removal of the liver or the genitals?
ebonyandivory
ebonyandivory PowerDork
6/15/18 2:54 a.m.
I hear the metallic colors are tough to remove:
Dusterbd13
Dusterbd13 MegaDork
6/15/18 6:30 a.m.
Ive never had a good platidip removal experience. Ever.
Laquer thinner is the best solvent so far.
Grtechguy
Grtechguy MegaDork
6/15/18 7:34 a.m.
Pressure washer will strip it right off.
6/15/18 9:22 a.m.
I've also heard that just a little gasoline makes it fall right off.
Harvey
Harvey GRM+ Memberand Dork
6/15/18 1:02 p.m.
Toluene and naptha apparently are the ingredients in the plastidip thinner product.
https://www.tapplastics.com/uploads/pdf/f740_MSDS_thinner.pdf
i8N0ZF20vNOZrqhltIsInBNPIVqVL5uSJMhcUcVbKmP3D3AmmLkKutr0I5ZjVr86
