Tom1200
Tom1200 PowerDork
6/13/24 4:29 p.m.
So in the 40 year saga that is my Datsun 1200 I've always simply cobbled together the best bits I had or used what ever I could get cheap. The only other rule I had was the car must remain reliable
 Close ratio gear sets are  available for the standard 56 series gearbox but they are fragile (I broke two) and so I went to a beefier 60 series street box which unfortunately has a huge gap from 2nd to 3rd.
On my current home track I absolutely have to use 2nd gear in one corner.  The gap between 2nd and 3rd finally wore on my nerves, so I sourced a 5.13 ring and pinion with the goal of eliminating the need to use 2nd gear
When I redid my gearing chart I was a bit shocked at what it told me. The lower gearing means the car will be coming off every corner 10-12hp higher in the powerband. The trap speed at the end of the short chutes are such that I won't need to upshift so I won't be losing out the time gained.
Well duh Captain Obvious gearing does matter..............my not doing this 10 years ago is especially silly considering when I was road racing a 125cc bike I would make gearing changes if the wind increased 3mph.
10-12hp may not sound like much but in the 1200 this is a 12-15% increase in power.
gixxeropa
gixxeropa GRM+ Memberand HalfDork
6/13/24 5:08 p.m.
Would be interesting to see some lap times in comparable conditions
Tom1200
Tom1200 PowerDork
6/13/24 5:36 p.m.
In reply to gixxeropa :
I would love to just install the rear end as an experiment but I will also be putting in a fresh engine......so tough to say.
gixxeropa
6/13/24 6:41 p.m.
In reply to Tom1200 :
Just need a pit crew to swap ear ends between sessions
6/13/24 7:08 p.m.
Quickchanges are expensive at first but they get cheaper the more gears you have...
Tom1200
Tom1200 PowerDork
8/18/24 11:25 p.m.
In reply to Pete. (l33t FS) :
Bringing this back to life as I finally managed.to get the diff installed.
I am going to end up running my next race with just the diff installed. So I will get a really good idea of what gearing alone will do.
theruleslawyer
theruleslawyer Reader
8/19/24 12:54 p.m.
I really want to put in a 3.90 rear end at some point. My local tracks I barely have to shift in 4th. 3.90 up from 3.42 would Give me a more meaningful amount of time in 4th since I have to shift anyways and be at a gearing advantage most of the time. It would also eliminate getting too low in 2nd on tight autocross corners.
CWd4rpbv72p5AzzCSZ4zn3XsGtjeDNoV8gSFPXHz2CghcHkY1E01N1tjjZMjlBNK
