minimac
minimac Dork
3/29/10 9:06 p.m.
Has anyone added one of the dozens of add-on chips that are advertised? I'm not talking "name" chips, like Dinan, etc.,but the generic ones foe $10. Snake oil or any improvement?
Streetwiseguy Reader
3/29/10 9:07 p.m.
Generally a resister to wire across the temp sensor to richen the mixture. Snake oil of the highest order.
stuart in mn
stuart in mn SuperDork
3/29/10 9:22 p.m.
Some of them are ripoff/counterfeits of the name brands, too.
laz
laz New Reader
3/30/10 12:23 a.m.
The best $25 spent in my LeMons car's budget was the cheapest E30 chip on ebay.
WilberM3
WilberM3 New Reader
3/30/10 12:29 a.m.
laz wrote: The best $25 spent in my LeMons car's budget was the cheapest E30 chip on ebay.
is that the spece30 flag colored car?
poopshovel
poopshovel SuperDork
3/30/10 8:52 a.m.
We ran en eBay 'Greddy copy' in the soupRturd.
minimac
minimac Dork
3/30/10 9:26 a.m.
poopshovel wrote: We ran en eBay 'Greddy copy' in the soupRturd.
Was there any measurable(even seat of the pants) difference attributed to the chip alone?
skruffy
skruffy Dork
3/30/10 9:37 a.m.
Streetwiseguy wrote: Generally a resister to wire across the temp sensor to richen the mixture. Snake oil of the highest order.
+1. An acquaintance of mine sells these things. It's a resistor in a block of epoxy with wires coming out. Sometimes there's not even a resistor in the block! Generally they don't do anything at all, worst case you loose 5hp and get worse gas mileage from running way rich. Some cars will get a check engine light for a failed coolant temp sensor.
You could just unplug the coolant temp sensor for free to test drive this "chip".
I'm often amused when they show up in searches for parts for my carb'd z car...
iceracer
iceracer HalfDork
3/30/10 10:14 a.m.
Resistors are avaialble at Radio Shack cheap. Put in line from the air intake sensor it tells the ECU to richen the mixture because of the denser air. Benefits ?
4cylndrfury
4cylndrfury SuperDork
3/30/10 10:27 a.m.
Please dont ask me how I know
WilberM3
WilberM3 New Reader
3/30/10 10:45 a.m.
Wonkothesane wrote: Streetwise guy nailed it, it's just a resistor and some wire, and it depending on the model and what they found it either richens or leans the fuel mixture out. They go in-line from the mass air flow sensor and make the computer think there was more or less air ingested. Not the proper way to do it.
i think what the OP is talking about is an actual chip that goes inside the ECU, its just a generic blank chip with an unknown tune loaded onto it.
MadScientistMatt
MadScientistMatt Dork
3/30/10 11:02 a.m.
I don't think you can get real chips for the cars in the OP's profile. But that doesn't stop people from selling fake chips for them...
Dr. Hess
Dr. Hess SuperDork
3/30/10 12:20 p.m.
There was a guy selling copies of legitimate Esprit chips. The Esprit community is very small. The author of the code kept getting him blocked on eBay, and he kept coming back. Also, the chips he was selling were a very early version of the code and actually rather dangerous to the motor.
poopshovel
3/30/10 12:34 p.m.
Well, the turbo certainly helped on the butt-dyno side of things. We didn't want the budget hit/learning curve of going with the megasquirt, so we figured "berkeley it. It's twenty bucks. Worst case, we put it back on ebay." I can't honestly tell you if it made a difference or not. IIRC it ran like E36 M3 with the stock ECU. The plugs always look perfect and it goes like stink.
m4ff3w
m4ff3w GRM+ Memberand Dork
3/30/10 12:47 p.m.
I know there are lots of pirated copies of e30 chips on FLeAbay
minimac
minimac Dork
3/30/10 2:27 p.m.
MadScientistMatt wrote: I don't think you can get real chips for the cars in the OP's profile....
Also have '98 Forester, '09 Mazda3, and '10 Nissan Versa.
belteshazzar
belteshazzar SuperDork
3/30/10 2:49 p.m.
I bought an ebay chip for my e30 like 5 years ago for $50 or something. The difference was worth $500, If I'd have had to pay it.
laz
laz New Reader
4/1/10 1:39 a.m.
Yes, my spec e30 is the german flag themed one pictured in my icon. My LeMons car is painted like a panda :)
zipty842
zipty842 Reader
4/1/10 2:01 a.m.
Anything that alters the air flow sensor signal is also has the side effect of changing the timing as well. i've never liked that idea.
MadScientistMatt
4/1/10 9:33 a.m.
There might be one for the Forester, but I suspect there isn't. Mazda3 tuning solutions exist but you'd use a flash (program loaded through the OBD2 port), not a chip. If anything existed for the Versa, it would also be a flash.
3bhXW4cUtHmZ8eUXkvP12JFof6qW4y8bc1oYwDCRPcAC3FDRBaxpiXELALPdefPp
