Tyler H (Forum Supporter)
Tyler H (Forum Supporter) GRM+ Memberand UberDork
5/14/21 11:41 a.m.
I am about out of ideas, so I'm lofting this to the hive, hoping for a fresh perspective.
Car -- 1998 E36 M3.  150k mi. Stock.
Issue -- Intermittent cylinder 1 misfire.  Once the CEL illuminates, it shuts off that injector and I have a dead miss.  Restart clears the dead miss.  Very predictable pattern.
Fault Condition -- Cold start, about a 3 miles into a drive cycle. Coolant temp >= 190, usually about 194.  Occurs after a low load coasting down hill.  After clearing it, it will not reoccur until another cold start.  Only thing in the freeze frame data that is weird is a spike in short term fuel trim -- Was +28% on bank 1.  LTFTs are 4-8%  STFTs are otherwise +- 2-4%. On a restart, the STFT goes back to normal.
Troubleshooting done so far:
  • New plugs.
  • New O2s.
  • Moved the coils around to see if it moved (no.)
  • Compression test -- 172-170-170-168-165-165.
  • Replaced the fuel injectors (thought #1 was leaking down during coasting and then over-rich when the injector fired back up.)
  • New CCV, all vacuum hoses, intake plenum boots, intake and TB o-rings
  • Cleaned MAF.
  • Smoke tested to check for leaks in the intake system (after all the new stuff) -- tiny wisp of smoke from the ASC butterfly, but no major leaks, and that's upstream from the common plenum.
What haven't I thought of?  Thanks!
Slippery
Slippery GRM+ Memberand UberDork
5/14/21 11:52 a.m.
You pretty much covered all the bases, if I was in your shoes I would probably swap the injector next. It's a piece of cake as long as you don't lose the clip ...
5/14/21 3:49 p.m.
In reply to Slippery :
Thanks, all 6 injectors are freshly replaced from FCP Euro. No change.
The only other hint, maybe: when I bought the car a few years ago, I would get a code for the charcoal canister valve stuck shut. I tested the valve and it was working.  Replaced it with a charcoal canister out of Pull-a-part and the code never came back.  I also replaced the fuel/vapor separator tank and fuel tank pressure sensor from the donor car, which was really freakin clean. My only hunch is maybe some EVAP or purge process is causing a lean condition??? Grasping at straws.
L5wolvesf
L5wolvesf HalfDork
5/14/21 4:31 p.m.
Food for thought . . .
Parts tossed at problem so far:
  • New plugs.
  • New O2s.
  • Cleaned MAF.
5/14/21 4:33 p.m.
Did you use a genuine BMW CCV?
Jesse Ransom
5/14/21 4:52 p.m.
Based on... the contents of my head, so... probably in left field.
Fuel rail layout on these? If they feed at the rear and return from the front (IIRC like my E30) could there be some obstruction at/near the #1 injector?
Unfortunately a clog there seems like it would probably interfere with the return and if anything force a trim the other direction...
Tried looking at #1 and any other spark plug for clues about conditions during combustion?
Slippery
5/14/21 5:50 p.m.
In reply to Jesse Ransom :
Correct, the rail is fed from the rear and the return comes after #1.
CyberEric
CyberEric Dork
5/14/21 8:58 p.m.
I had a 1999 M3 that went through what seemed like a lot of coil packs, maybe 2 or 3 in one year once, so I came in here thinking it was one of these. I guess I'm no help.
Jesse Ransom
5/15/21 2:43 p.m.
So...
The misfire happens on a cylinder:
  1. That has compression
  2. That has a coil that works elsewhere
  3. That has a new injector just like the rest
I think "air" generally can be assumed, and "compression good" mostly means "air is correct/reasonable."
So something is wrong with either fuel or spark.
  • If spark is a problem, it's probably upstream of the coil (I feel like there's probably some room for vagueness in chasing a timeline on when coils were swapped relative to spark plugs; you'd think it would *eventually* move with a bad coil if the coil caused plug #1 to quasi-foul, but it does leave a little room for the problem to stay with the plug.)
  • If the problem is fuel, it's upstream of the injector (or the new injectors included a dud that happened to wind up in the same spot. Once again just noting the highly improbable but conceivable). "Upstream" on fuel means both electrical and fuel supply. Connectors, grounds, actual driver... It'd be so weird to have a fuel rail issue that only impacted one injector...
And that's kinda where I'm at. I think we're into the realm of something reasonably arcane and weird, but somewhere there's a concrete reason. Now it's a matter of locating it.
dean1484
5/15/21 3:13 p.m.
I would put a bore scope in that cylinder and give it a really good inspection. I am thinking there is something wrong that is "fixing" its self when it gets warm.
5/15/21 5:34 p.m.
Thanks all for the input.  Will keep you posted.
Just for giggles, I pulled the plug to the EVAP purge valve and car ran great and no issues across several drive cycles today.
5/15/21 5:36 p.m.
I have a bore scope and will do so and post some pics next time it happens.
5/15/21 5:37 p.m.
Jesse Ransom said:
So...
Arcane sums it up! Perplexing and it freaking runs great other than when it does this BS. :)
5/22/21 3:07 p.m.
I unplugged the purge valve from the wire harness on a hunch and haven't had any other misfires since.
Does the ECU lean out the mixture while the purge valve is open?
I suspect the evap hose might be damaged south of the purge valve, creating a lean condition when the valve is open.  Maybe this would yield the high short term fuel trim, trying to compensate for richer fuel mixture when purging?
I'll segment out the evap system and check for leaks.  I know OBD2 looks at the tank pressure and runs a test to verify if it's leaking.  Not sure if the purge vent hose past the tank is tested?  I would assume the DME would look for the mixture to richen when the valve was open to indicate it was working?
Might put an LED on the purge valve connector and plug it back in to see if there is correlation between the valve opening and the misfire.
jfryjfry (FS)
jfryjfry (FS) Dork
5/23/21 12:07 a.m.
Sounds like you might be on the right track but if it isn't it, look at your valve train.  That can cause issues specific to a cylinder.
Colee36
Colee36 New Reader
8/26/24 11:11 p.m.
In reply to Tyler H (Forum Supporter) :
Hey Tyler, having a similar issue with my e36 at the moment. I've tried swapping spark plug, coil packs, and fuel injectors around and am still getting my misfire on cylinder 4 only. Also smoke and comp tested it with good results from both. My 4th cylinder is doing the same thing you've described, slight misfire and then completely cutting the cylinder off completely after a load on the engine. I'm wondering if you ever found out the issue? I'm going to be testing the wiring soon but was just curious if you figured it out. Thank you! (Sorry to bring an old forum up from the dead but you're the only person I've found online that's had a similar issue)
Tyler H
Tyler H GRM+ Memberand UberDork
8/27/24 7:33 a.m.
It just decided that it was done doing that garbage and has been fine for years.  The only thing that was weird is that the STFT spiked, indicating a lean condition.  I never logged coolant temperatures to see if there is any weirdness when it was warming up or when the tstat opens, so maybe I'll go back to that.
My gut still says that there is something related to EVAP purge, like a cracked hose somewhere under the car that was admitting air when it should be expecting a rich condition during a tank purge.  Either way, it quit doing it so I quit chasing it.
Good luck!
RacetruckRon
RacetruckRon GRM+ Memberand SuperDork
8/27/24 7:58 a.m.
Have you checked the wiring to the coil and injector on this cylinder? If new plugs, injectors, and swapping coils around didn't fix a cylinder specific misfire I'd be looking over the wiring really carefully.
Tyler H
8/27/24 8:35 a.m.
I haven't really looked over it.  The car is really in pretty great shape and I haven't seen any other issues with the wiring or insulation deteriorating, but I suppose it could happen.  When it was doing it, the conditions were incredibly predictable - to the point I could guess within a couple hundred feet on my drive that it was going to occur.  Turn the key off and back on, and it would run perfectly from there on out.
yr2dghu6exgxFLpR2hxkyrPgXtzKUgThGoUDEADSGNFIeZipfz5JuaErkaNzkW2W
