redhookfern
redhookfern Reader
9/10/13 10:00 a.m.
So I just picked up the new ride, and my 3rd E46 (2003 xi). The general module was dead when I got the car, so they kindly swapped in one from a same year wagon that they had. The problem I am discovering now is that not all module's are created equal, and I need a sedan. I think I found one from a same year sedan, model, etc. but was wondering if any of you had to replace one of these, and if so, what sort of re-coding was required when you were done. When they put this one in, I lost my alarm, my mirrors won't function, and my trunk says it's ajar. I have been told that this is because they put a wagon version of the GM5 in. Am I to believe that if I put the sedan GM5 in, this should rectify the problem?
Also, has anyone ever replaced a window regulator? Any tips. Mine is shot in the back rear door and the notorious zip tie fix won't apply here.
Sonic
Sonic SuperDork
9/10/13 10:31 a.m.
I did the front window regulators in my moms e46 wagon, and it was straightforward and easy once you get the foam off without tearing it to get into the door
tXowzhMBo7Edz98yBURDhsSmlo5NlGsoz0JevaaZ6tRZkC7wl2mX7RxSFG3tQQOQ
