If you hear people talking about E85 like it’s some sort of magic bullet, that’s because it kind of is.
E85 is, of course, the high-ethanol blend of gasoline available in many areas of the country. Its elevated ethanol content makes its relative octane rating extremely high, which in turn means that it’s highly knock resistant.
The downside is that …
"Including, hopefully, the Miata. Yes, we suggested it. You’re welcome."
You guys really are the best...
Aww, shucks. Credit JG for that bit of diplomacy.
does anything happen when E85 gets on your hands or paint job etc
there is not much E85 around here.....
Your test of fuels showed that methanol is best of all - I think a very hardware-light methanol-specific engine build could give some startling performance, either with a very high static compression ratio or a nonintercooled forced induction system.
Yeah, but if I remember correctly it used a staggering amount of fuel for a small increase.
In reply to z31maniac :
Not to mention the fact that methanol burns almost completely clear, making it a little hard to tell if it's on fire.
And if it'll work on the Miata, it'll work on BP powered BG chassis cars as well
It's gasoline and alcohol. Neither are good on your skin .
E85 isn't at every gas pump but there is likely a whole lot more than you think. There are apps for finding it.
Ethanol and methanol are two different alcohols. Ethanol is in beer wine and booze.
Methanol if you drink and first you go blind then you die.
Indy has been using ethanol for a long time now.
power gain is totally dependent on what you are using it for. High compression? Boost? Gains can easily exceed 30% maybe more.
When I use E85 in my Ford. It costs me about 2 mpg from 22 down to 20mpg.
Sprint cars and drag racers will use as much as 50% more to make the extra 30+% horsepower gain.
In reply to Colin Wood :
You can't see it but the entire CART pit lane knew instantly when there was a big fire. It's harder to ignite than gasoline, and is extinguished by mixing it with water. The back of the pitwall had dozens of five-gallon buckets to throw.
For some more talk about methanol, check out our latest Fuel Tips.
Yes. CART engines didn't need intercoolers because the methanol's evaporation got the plenum air temperature down to ambient.
Methanex's bulk price for methanol is <$1.00/gallon. Since there aren't any additives needed, why can't I get it for less than five bucks a gallon?
Larger injectors will be needed, and tuning will have to be done, but the two reasons not to run it in a race are "it's banned" and "we can't get a big enough tank in the car to finish" - are there any more?
Maybe. Maybe not. There are a lot of Miatas that don't have BP-related engines :) Every one produced in the past 15 years, for example. And if it's interacting with anything other than the injectors themselves, you'll get into the question of how ignition timing is controlled.
So this thing looks like it's reading the ethanol content of the fuel and then extending injector pulse width appropriately. Yes? There must be some sort of timing shenanigans going on as well to actually get more power. I like the fact that it has a sensor, that's important because E85 can actually be E70.
If you REALLY want to benefit from E85, you need to put that engine under pressure.
In reply to chaparral :
First reason not to use methanol is it will kill you. On your skin it's evaporating really fast so it will feel cool. But it's being absorbed too and that's tough on your organs. Cancer and other bad words tough.
breathing methanol will also do bad things to your lungs.
Second ethanol can be drunk ( pun intended) whiskey whine beer all have ethanol in them.
Methanol on the other hand, first you go blind and then you die if you drink it. Both methanol and ethanol are alcohol one is safe, one is death.
Methanol fires are invisible. The first time you notice it may be when your burning skin adds a little smoke to the fire. E85 the flame is visible.
You can get methanol that cheap but won't be "fuel grade" you will have to filter it and remove water. I think about $6/gallon is about as cheap as I have seen useable methanol.
Twice the fuel system flow as gasoline, which may or may not be easy. Most of the reason not to use it is that for the same race, you need twice the fuel, and it's not light. When you are going 1/4 mi its no big deal. 24 hrs it gets thirsty.
I have been using VP M1, VP M5 and some custom blends for years. I use full PTFE lined hoses, appropriate hardened fuel rail and fuel fittings, all PTFE seals, and all stainless internal injectors. It adds up quickly, but the M5 was a 30whp gain (~10%) over pump E85 measuring 82% ethanol with no other changes.
I notice there is a conspicuous lack of emissions information on the product website. Product support may not be available over the long term.
In reply to Keith Tanner :
With regard to? On road or off road? Assuming there's no lead, race only fuel is rather open in what is allowed. For on road, the effects of E85 and the relative changes is pretty well known.
That's one of my future plans... when we get more e85 around here.
It's clearly being sold for road car use and is available to anyone with a credit card and an internet connection. Thus it is for road car use in the eyes of the EPA. The effects may be well known, but in order to sell this for road car use you need to prove it does not adversely affect emissions. Not wave your hands and say it's well known, but spend time in the lab and show the numbers. These guys are messing with the fuel and possibly the ignition system including replacing injectors, so they will need to provide that proof. They're even selling to California which means the ARB will also be interested.
The fact that they're not actively bypassing emissions controls will help, it puts them a little further down the line in terms of enforcement priority.
You mean the kit, ok, Spot on.
I like cheap. E85 from a pump is many dollars a gallon cheaper than buying race gas by the drum. On a short 20 lap race I can add three gallons or about 21 pounds without any real weight penalty.
But LeMons or Champ Car racing with 5 minute minimum pit stops that adds a couple extra laps per extra filling to a car that already has twice as many fuel stops to better mileage cars. If Instead of 10 MPG I'm. Getting 6-7 plus a 15 minute penalty. It means the car just can't be competitive even if it's stone reliable.
I've found through testing the highest content of ethanol is late in the fall when depending on what I buy can contain up to 86% ethanol and trace amounts of water.
In the spring that same station/pump may be selling 46% ethanol & 8% water
Because of the dangers of Methanol ( as compared to ethanol ) I won't touch that stuff. Besides it's "octane " is 116 as compared to ethanol's 114. That slight difference is just not worth the added risk.
On my Flex fuel truck I lose 2mpg going to and from work. But when it cost as much as 70 cents a gallon less I still kept $5 a tank ful in my pocket.
Octane is just the anti-knock ability, there is also the cooling effect and BTU output at target AFR. Methanol wins for both of those. I understand the relative ease of using E85 (if pump E85 is available, we used to have it but it's no longer available and need to get it through race suppliers).
That's interesting.
I know in Oklahoma, E85 is really E70. And it's E70 year round as that is what is guaranteed by law as the minimum content...........so that's all it ever is. Unless you go to one of the few stations that sell E100. But everything I've read says really past about E60 you aren't gaining much more power.
E50-E98 power difference depends a lot on what it's blended with. There are some interesting things that happen with lower ethanol content and unleaded, high octane gasoline. My highest "ethanol" pulls have been on VP E50 on naturally aspirated high compression, but on turbocharged E98/X98 would win (as intake temperatures are much higher).
