Grtechguy
Grtechguy UltimaDork
9/27/13 9:08 a.m.
What should starting fuel pressure be? I measured at 52-53 lbs with key on. Stuck at a cranking no start condition.
Pulling the ignition module/coil pack I can get spark (looks orange?) at each of the plugs.
Gearheadotaku
Gearheadotaku GRM+ Memberand UberDork
9/27/13 10:24 a.m.
spark sounds weak, most newer systems are blue or white sparks. Are you getting injector pulse? Give it a squirt of starting fluid.
Cone_Junky
Cone_Junky Dork
9/27/13 10:41 a.m.
Grtechguy wrote: What should starting fuel pressure be? I measured at 52-53 lbs with key on. Stuck at a cranking no start condition. Pulling the ignition module/coil pack I can get spark (looks orange?) at each of the plugs.
What year/model vehicle is it in/from?
Grtechguy
9/27/13 11:07 a.m.
04 Grand Am Se with a manual.
Edit: A little background. Died last saturday after a few short trips ( Under 10 miles). My father was driving. Started the car, Put into reverse and drove backwards about 10-15 ft and stalled.
Previous to this, it was running flawless.
Cone_Junky
Cone_Junky Dork
9/27/13 11:12 a.m.
Alldata lists key ON engine OFF pressure at 50-60 PSi
Sounds like that isn't your problem
I did see more than a few problems reported with the crank sensor.
JohnRW1621
JohnRW1621 PowerDork
9/27/13 11:18 a.m.
You have not thrown the chain/tensioner, have you?
Not as common on '04+ models but very common on earlier models.
http://www.youtube.com/watch?v=M0WRDlk7Ew4
http://www.youtube.com/watch?v=IbjDCkrFlHg
Grtechguy
9/27/13 11:20 a.m.
JohnRW1621 wrote: You have not thrown the chain, have you? Not common on '04+ models but very common on earlier models. http://www.youtube.com/watch?v=M0WRDlk7Ew4
I hope not...
JohnRW1621
9/27/13 11:32 a.m.
The 2.2 Ecotec was first offered in the 2000 Saturn L-series. Here is a link from the owners.
http://www.saturnfans.com/forums/showthread.php?t=72096
N Sperlo
N Sperlo MegaDork
9/27/13 11:45 a.m.
Fuel pressure when engine is running only eliminates the pump, lines if I'm not mistaken. How long does it maintain pressure once the pump shuts off?
Grtechguy
9/27/13 12:39 p.m.
N Sperlo wrote: Fuel pressure when engine is running only eliminates the pump, lines if I'm not mistaken. How long does it maintain pressure once the pump shuts off?
Engine isn't running. It's held pressure overnight
Kenny_McCormic
Kenny_McCormic SuperDork
9/27/13 1:42 p.m.
Orange spark, bad coilpack?
N Sperlo
N Sperlo MegaDork
9/27/13 1:54 p.m.
Right. My bad. I meant after you turned the power off (which shuts the pump off). If it has held pressure, you've ruled out leaky injectors, which wouldn't kill the engine easily anyway.
I'm with the spark guys. Swap the coil pack?
Ranger50
Ranger50 PowerDork
9/27/13 2:15 p.m.
Doesn't this wheeled box have like 170k+ on it?
Grtechguy
9/27/13 3:06 p.m.
Ranger50 wrote: Doesn't this wheeled box have like 170k+ on it?
yep.
Grtechguy
9/27/13 6:52 p.m.
and berkeley.
JohnRW1621
9/27/13 7:26 p.m.
Here is a time when it sucks to be right.
2.2L's are cheap and plentiful.
http://grandrapids.craigslist.org/pts/4035192634.html
Buy without the trans and it could be as cheap as $300 for the engine.
http://grandrapids.craigslist.org/pts/4090120756.html
http://grandrapids.craigslist.org/pts/4075455792.html
If you get a replacement engine, drop in fresh components kit before installing which can be gotten through RockAuto or eBay.
Sample: http://compare.ebay.com/like/150898878739?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
Grtechguy
9/27/13 8:35 p.m.
Would it make a difference if mine is a manual and those are all automatics?
JohnRW1621
9/27/13 9:20 p.m.
No.
2cqjBu47RvYcNfHLiWDnZMtcwCDKbjVPqei2QqzZGt1Ov7hSOITG6UWY5ENgnpPM
