I know I'm not as familiar with the SCCA rules as I could be. I know some of you are. So, for a dream build say I want to build an electric autox car. This would be less of "put big sway bars on a nissan leaf" and more of "build a modified class car that happens to be electric".
How could this be classed? Does it even have a place to run? Does the answer change if I decided to use the electric motor from a production car instead of an aftermarket motor?
Looking at the rules. Page 225 SM engine classification #4
Looks like EMod let's you run electric as well. But those are the only 2.
As a reflex answer, I'm only prepared to answer for E Mod, but there is a weight requirement in E Mod for electric powered vehicles. 1800lb minimum. That would be based on a production car body/tub.
I'm no help elsewhere in Modified without further research, though if I remember right, A Mod is pretty much no-holds-barred, anything goes.
hmmm, yes, I see the min weight for SM electric is 2900 lbs. That would be far above what I'm planning on. and E mod still has the 'production-vehicle' clause that restricts snowmobile and motorcycle engines, so I think that would exclude an aftermarket electric motor as well.
Amod might let it run I guess, but 900 lbs is very light!
