AndreGT6
AndreGT6 Dork
3/22/13 9:00 a.m.
So while I have the engine out of the race car I figure I should clean and paint the bay.
Tempted to use an engine block paint.
Thoughts.
A.
GameboyRMH GRM+ Memberand UltimaDork
3/22/13 9:15 a.m.
For sheer durability I'd go with bedliner instead, if looks don't matter.
AndreGT6
AndreGT6 Dork
3/22/13 9:21 a.m.
It should look tidy but resistant to chemicals is important.
carguy123
carguy123 UltimaDork
3/22/13 9:22 a.m.
Tractor paint from Tractor supply. Easy to apply and very durable.
It comes in many more colors than just John Deere green.
AndreGT6
AndreGT6 Dork
3/22/13 9:25 a.m.
Aiming for white.
3/22/13 9:26 a.m.
carguy123 wrote: Tractor paint from Tractor supply. Easy to apply and very durable. It comes in many more colors than just John Deere green.
^This is what I was gonna suggest next. Probably the 3rd most durable option behind Bedliner, and then Hammerite & similar, and looks a lot like engine block paint but won't flake off if you don't heat-cure it right.
3/22/13 9:32 a.m.
AndreGT6 wrote: It should look tidy but resistant to chemicals is important.
I recognise a Fiat 124 engine bay anywhere... one of the few areas of the 124 that doesn't rust
AndreGT6
AndreGT6 Dork
3/22/13 9:34 a.m.
mad_machine wrote: I recognise a Fiat 124 engine bay anywhere... one of the few areas of the 124 that doesn't rust
Bohaaaa
I'll look around for products this weekend. I need to finish off the exhaust upgrades then I can pull the spare block and head out.
Will time a few hours to prep and cover everything.
dinger
dinger Reader
3/22/13 2:09 p.m.
Tractor paint works great, BUT! make sure to use the enamel hardener as well. It seems a bit expensive at $13 per pint, but the paint will dry WAY faster, get MUCH harder, and be MUCH more chemical resistant.
Dusterbd13
Dusterbd13 HalfDork
3/22/13 4:31 p.m.
the last few ive done were semi=gloss black /gm bays. used a spray can from john deere place. o couldnt hurt it....
Appleseed PowerDork
3/22/13 10:42 p.m.
Black. Hides oils leaks.
kanaric
kanaric New Reader
3/23/13 1:35 a.m.
GameboyRMH wrote: For sheer durability I'd go with bedliner instead, if looks don't matter.
I agree with this actually.
Bedliner is an actually fantastic choice and i've seen it done before.
Eoe7zwIuDvjzRXkjnLJMZK89d5hcGkwXlqefAVsc5FR5quaxLODTlDTSl2C5cAn2
