44Dwarf
44Dwarf Reader
6/22/09 8:00 p.m.
Hi Gang. Need some math help. I've got a motor with an aftermarket crank button on it and no timing tab....
crank stroke is 48.7mm I need to find out how far down the piston top is at 20deg BTDC and 40 deg btdc I don't know rod length either.
Anyone know the formulas?
thanks 44
RealMiniDriver
RealMiniDriver Dork
6/22/09 8:18 p.m.
Difference in rod journal height would be:
20° = 1.4685mm
40° = 5.6968mm
I'm not sure what impact rod length would have on these measurements, if any.
44Dwarf
44Dwarf Reader
6/22/09 8:32 p.m.
darn close I found the formula in my 2 stroke notes from days gone by.... T= L+Rx(1-cosA)- square root of L^2-(RxSinA)^2
where A= angle in deg L= con rod length (strokex2 if unknown) R=stroke / 2
i came up with 20 deg = 1.4834 and 40 = 5.7485
Thanks 44
0R7ZIc8aSE0I9KHluOEJ6Mxd7I4GWH9RoEV6ScLzL1ckpI5nsEtY7rMTjoAHsNnl
