RexSeven
RexSeven SuperDork
3/21/12 6:15 p.m.
I have a set of 18x8" OZ Ultraleggeras with (I think) 67.1mm center bores. They fit my Mazdaspeed3. One of the new cars I am considering has the same bolt pattern as the MS3 but has a 70.5mm center bore. If I take it to a competent wheel repair shop, they should be able to bore it out safely, right? The change in bore size is only 0.14" (3.4mm).
Javelin
Javelin GRM+ Memberand UltimaDork
3/21/12 6:24 p.m.
Yup. As long as there's enough meat there, this is a simple and often-performed procedure.
44Dwarf
44Dwarf Dork
3/22/12 7:23 a.m.
Any machine shop with big lathe or a "gap bed" lathe should be able to do this no problem.
logicfactory
logicfactory New Reader
3/22/12 9:42 a.m.
here is my unsolicited advice.
i have strong opinions about running larger wheels than what make rational sense in regards to performance. i believe in running the smallest diameter that can clear your calipers while providing the width one desires. if you wanted to run 10+ inch wide 18's than your situation falls into the grey area. it would than make more sense to go 18's because of the increased tire and wheel options; e.g. 18x10 wheel and 265+ widths. but the size you are wanting to run does not conform to this logic. 225's are pretty common place in 13-17's diameters.
run what you are happy with but if you want to chase efficiencies in an effort to increase performance than the aforementioned advice could be considered.
92CelicaHalfTrac
92CelicaHalfTrac MegaDork
3/22/12 9:47 a.m.
logicfactory wrote: here is my unsolicited advice. i have strong opinions about running larger wheels than what make rational sense in regards to performance. i believe in running the smallest diameter that can clear your calipers while providing the width one desires. if you wanted to run 10+ inch wide 18's than your situation falls into the grey area. it would than make more sense to go 18's because of the increased tire and wheel options; e.g. 18x10 wheel and 265+ widths. but the size you are wanting to run does not conform to this logic. 225's are pretty common place in 13-17's diameters. run what you are happy with but if you want to chase efficiencies in an effort to increase performance than the aforementioned advice could be considered.
I believe the Mazdaspeed3 had 18" wheels from factory, so....
Brett_Murphy
Brett_Murphy GRM+ Memberand Dork
3/22/12 1:00 p.m.
I did my own center bore increase on Escort GT 15" wheels with two hole saws stacked inside of each other. I took my time and they fit on the hub of my VW really well.
Granted, I wouldn't trust that method for a car that is driven on the street or the track. That was for a rallycross only car, so if they break, no real harm done.
In case your're wondering, to go from a 54.1 (Miata, Escort GT) to 57.1 mm (BMW, VW) I used a 2 1/4 inches stacked on a 2 1/8 saw with a few big washers used to offset them from each other.
Again, I would not do this on a street driven or track driven car, pay the money and let somebody do it on a precision machine.
Zomby woof
Zomby woof UltraDork
3/22/12 1:12 p.m.
If you're handy with it, you can do it with a router.
pilotbraden
pilotbraden Dork
3/22/12 1:59 p.m.
Zomby woof wrote: If you're handy with it, you can do it with a router.
I am certain that Red Green would do that. He is pretty handy.
GameboyRMH GRM+ Memberand UberDork
3/22/12 2:03 p.m.
Hey, if the women don't find you handsome...
singleslammer
singleslammer PowerDork
9/11/17 12:00 a.m.
Zombie thread.
I might need to do this on some wheels soon. Likely going from 72.5mm (bmw) to 74mm (Jag xj). Thoughts? It isnt even a mm of material...
dculberson
dculberson PowerDork
9/11/17 6:28 a.m.
Might want to check that math. ;)
i wonder if you could put sandpaper around a close fitting hole saw and run it inside the bore to enlarge it? Get the good sandpaper!
EvanB
EvanB GRM+ Memberand UltimaDork
9/11/17 6:41 a.m.
I have some to do as well from 63.3 to 65.1 (Merkur xr4ti to Saab 900). I am planning on using a belt sander/dynabrade or flap wheel to remove the material.
DeadSkunk
DeadSkunk UberDork
9/11/17 7:10 a.m.
There are a few YouTube videos of this being done with a router and a carbide bit. I keep meaning to try it on a scrap wheel to see how well it works out. Otherwise, I'd take them to a machine shop and have them turned on a lathe.
Ashyukun
Ashyukun GRM+ Memberand UltraDork
9/11/17 7:57 a.m.
I did this (by a very, very small amount) with the nicer Toyota (I think...) wheels that I got and put on the accursed Jeep Patriot I had. They were *juuuuust* too small to fit over the hubs, so I got a drum sander pack from HF and used that the get the clearance necessary to fit them on the Patriot.
z31maniac
z31maniac MegaDork
9/11/17 8:26 a.m.
Been roundly shown more tire = faster times in basically every scenario. Even with an increase weight.
djsilver
djsilver Reader
9/11/17 8:49 a.m.
In reply to Brett_Murphy :
You can do this and I wouldn't worry about a rally-cross car, but if you want the wheel to remain hub-centric you'd have to take them to a machine shop.
T.J.
T.J. MegaDork
9/11/17 9:34 a.m.
I miss SF1 posting here. I didn't realize this was an old thread until I saw his post and then saw that it was from 5 years ago.
singleslammer
9/11/17 9:50 a.m.
In reply to dculberson :
Am I missing something?
(74.1 - 72.5)/2=0.8mm
dculberson
9/11/17 9:56 a.m.
Ahh, no I wasn't dividing by two. I R Smrt
singleslammer
9/11/17 10:06 a.m.
cheeky no worries
I was thinking a drum sander on a Dremel and a lot of time. It is just so close.
xflowgolf
xflowgolf Dork
9/11/17 12:14 p.m.
This is where a machine shop buddy comes in handy.
I've found a lot of machine shops won't do this on the books because of liability fears, and a lot of wheel specialty shops that do advertise it often charge enough to not really be worth it vs. just selling / buying wheels that fit.
But if you know a guy.... it's really not much work at all once it's set up, and I've had success in the ~1 case of beer payment after hours.  cheeky
XZXPp4uFb33dDP78MqfMwTdtL0xT4Lfn0yts4ejibBvBg5ryLnIgTZsvLRWfQ6T2
