Gearheadotaku
Gearheadotaku GRM+ Memberand UltraDork
6/27/13 2:52 p.m.
I need to find an engine for a 2001 Eurovan.
2.8 V6, reman preferred.
Not for me, it's work related.
Anyone got a source?
xflowgolf
xflowgolf HalfDork
6/27/13 2:54 p.m.
long shot... but call Jeremy at Blough's in Freeport, MI. They tend to end up with odd stockpiles of VW drivetrains. (616) 765-8801
Gearheadotaku
6/27/13 3:09 p.m.
Strike 1...
Slippery
Slippery GRM+ Memberand Reader
6/27/13 3:29 p.m.
Isn't that engine similar to the VR6? If so, it will probably be easier to source and swap over some of the parts (cams, etc if they differ)
Somehow I believe its the same engine with a small bump in cc ... But not 100% sure
DukeOfUndersteer
DukeOfUndersteer UltimaDork
6/27/13 3:34 p.m.
Vortex.
SlickDizzy
SlickDizzy GRM+ Memberand UberDork
6/27/13 4:45 p.m.
Slippery wrote: Isn't that engine similar to the VR6? If so, it will probably be easier to source and swap over some of the parts (cams, etc if they differ) Somehow I believe its the same engine with a small bump in cc ... But not 100% sure
It isn't just similar, it IS a VR6. Someone on the Vortex is bound to have one.
AngryCorvair
AngryCorvair GRM+ Memberand PowerDork
6/28/13 9:45 a.m.
check out Munk's Motors in Waterford MI.
two four eight
six eight one
eighty eighty-two
JohnRW1621
JohnRW1621 PowerDork
6/28/13 10:28 a.m.
Is there still the VW place next the Silverdome?
http://www.partsplaceinc.com/
audifan
audifan Reader
6/28/13 1:11 p.m.
you do not need a eurovan motor as the 24v vr6 from a jetta/gti will work it will take some swapping of manifolds etc but it will work. this will save you alot of headache. And if your doing this as a timingchain scenario (chain/pulley failure on current engine) then also relplace those same parts on the new to you engine good luck PM me if you have questions
bearmtnmartin
bearmtnmartin GRM+ Memberand HalfDork
6/28/13 1:24 p.m.
A friend of mine with an unhealthy love for Eurovans bought a 5cyl TDI for his from a German version.
Gearheadotaku
6/28/13 2:14 p.m.
JohnRW1621 wrote: Is there still the VW place next the Silverdome? http://www.partsplaceinc.com/
That was one of my first calls.
good try though
ultraclyde
ultraclyde Dork
6/28/13 2:19 p.m.
There's a whole eurovan on the Columbus, GA craigslist....
Ian F
Ian F PowerDork
6/28/13 2:28 p.m.
Vortex. A search on the MkIV parts classifides turned up a few VR6 cars. This one doesn't seem too far from you, although it seems the seller is a typical Vortexer:
http://forums.vwvortex.com/showthread.php?5953206-Third-times-the-charm.-Selling-parting-out-2003-VR6-OEM&highlight=VR6
...and there are others.
Gearheadotaku
6/28/13 3:48 p.m.
looks like a co-worker found something.
Thanks for the input guys.
AngryCorvair
6/28/13 3:50 p.m.
Gearheadotaku wrote: Thanks for the input guys.
that's what she said!
OsEIGHQWz19UYQbCWTJBQAqQSFfMbUIrBYFtMUar8Lz40hTxwyibMMdzdkLgJ2WH
