I've got a 2013 LFX V6 in my 1966 Chevelle. It's 3.6L, 217 ci, 4 valves per cyl, direct injected and naturally aspirated. These engines have internal exhaust manifolds so just one exhaust port in each head. There are down pipes with 4 catalytic converters (2 per bank). I'm running the stock down pipes but only the primary cats. The secondary cats located after the second O2 sensors have been removed. The down pipes are 2.5" diameter.
From the end of the down pipes I've installed a Pypes 2.5", 16 gauge stainless steel, mandrel bent exhaust system all the way to the rear bumper. It includes an X pipe and is supported by factory hangers at the rear of the mufflers and the rear of the tail pipes.
I originally installed Flowmaster 50 Series Delta Flow mufflers. They were pretty quiet but I wasn't happy with the drone so I have since installed Walker QuietFlow lll mufflers. The QF lll's are 2.5" in/out but do neck down to 2.25" internally.
So while the drone is gone the system is much more raspy. I mean it sounds like crap. It sounds like an old truck or even a tractor. In thinking that maybe the system at 2.5" was too large for the 217 ci displacement, I blocked one half of the system at the tail pipe outlet. It sounded WAY better but still raspy.
So here are my questions:
1. When I blocked one half of the system at the end of a tailpipe I basically turned everything past the one leg of the X into a huge Helmholtz chamber, muffler and all. What affect could this have had and should I have blocked it at the X instead?
2. Should I be considering a single exhaust for this tiny engine? Would mixing and keeping the exhaust flow together for the entire length disguise the V6 cadence any? Maybe smooth it out some? And if so, is a single 2.5" muffler/tailpipe adequate for 217 ci?
3. The Flowmasters had a MUCH lower tone so I'm thinking I probably should have kept them and added resonators in the tailpipes to kill the drone. Anyone have experience with resonators after Flowmasters?
4. Chevelles locate the mufflers just before the rear axle. This as far back as you can locate a muffler in these cars. Would there be any benefit to moving the mufflers forward a little? I read somewhere that you should always have a minimum of 6" of straight pipe after a muffler before any elbows.
5. Would dropping the tail pipes down to 2.25" or even 2" affect the sound any? I'm quite sure with 2- 2" tail pipes I have plenty of pipe for my engines displacement?
6. I do not have a flex section in the system. Would adding SS flex sections after the cats and before the X help any with resonance?
7. Should I update the hangers to something more current to further isolate the system from the body/frame?
8. I swear I've seen muffler wraps before but can't seem to find any now. If I'm remembering correctly they were preformed of that multi layer dimpled material you would normally see in later cars as heat shielding and were held on with stainless zip ties.
Any other suggestions, ideas, feedback would be appreciated. I'm looking for the quietest, lowest tone I can get given I'm challenged in the displacement department.
