thatsnowinnebago
thatsnowinnebago GRM+ Memberand SuperDork
3/11/19 11:29 a.m.
Hey all, is this the factory timing belt for a 99 miata? It seemed to be in good shape for having potentially 112k on it.
calteg
calteg Dork
3/11/19 11:31 a.m.
Flip it to the other side and create a  slight "U" bend. See how many cracks there are. All of the timing belts I've replaced have had hairline cracks, but seemed to be in good shape otherwise. For $20ish bucks, it's cheap insurance to replace
3/11/19 11:37 a.m.
I've seen one that was in great shape other than the fact that it was broken. The numbers on that belt are plausible for factory.
TurnerX19
TurnerX19 Reader
3/11/19 12:11 p.m.
Once a timing belt is removed it should be replaced if it has been run more than a few miles, or if it is a year old or more if un-run. Seriously, they take a "set", and if you remove and re-install you will over tension it.
bmw88rider
bmw88rider GRM+ Memberand SuperDork
3/11/19 12:31 p.m.
The number says aftermaket. Looks like it should be a Denso part number.
Woody
Woody GRM+ Memberand MegaDork
3/11/19 1:14 p.m.
For God's sake, do not crimp it.
thatsnowinnebago
3/11/19 2:02 p.m.
That belt is already in the trash pile while the new belt will go on tonight, don't worry. I didnt dig this far into the motor to cut corners. Just satisfying my curiosity wink
Indecisiverock
Indecisiverock New Reader
3/11/19 6:31 p.m.
It is indeed the OEM belt, P/N for it is B6S7-12-205D-9U if you plan on ordering another oem one.
oFkyAUctpHB9RxFdNB9KEnmvaIFwU2UV8TPKEavV6n111LNWdocHPQPtt6LUZ4yn
