ckosacranoid
ckosacranoid SuperDork
6/29/21 5:40 p.m.
I have my fans on my 06 subby wagon having issues with not working at times. They can be tested and they work. Then a  couple of days later they do not work again. This comes before and after fixing the O2 issue I posted about last month. I know there is something about grounding issues with this year of Subaru Impreza wagon. I just can not find details that might help fix the bloody issue since I have to start driving the car more than it has been. I have replaced the temp sensor the start with everything and did the thermostat.
6/29/21 11:22 p.m.
Are the wires E36 M3ty? If you bump the blades once it goes dead and it starts spinning, might be a dead spot on the armature. Are there relays involved?
eastsideTim
eastsideTim PowerDork
6/30/21 9:05 a.m.
Regarding grounding issues, I recall adding a ground strap to my 95 Legacy between the engine and body and it did cause my voltage to go up to a more appropriate value, and I think it seemed like it idled a bit smoother, too.  I think I just used a somewhat heavy gauge wire, and a couple of crimp connectors to make the grounding wire.  Might be worth doing without any further diagnosis, since it is low risk, low effort.
sjjAzcyxnjszAAje4hfTL8zc8HHNYx68JEFgaBaQkmTFhRxDCKoMvq36KkWr3hig
