As an instructor I'll pass on some things I work on that may help give you an idea of what to expect although your actual instructor may have a different style:
Overall I just want you to know where the track goes, where the turn stations are, to be smooth and have fun.
Beyond that...........caution this will be long winded (possibly disjointed as its late)
I try to get students to pick one gear and stay in it as that will allow them to focus basic lines. At the same time I will nag about not shuffling you hands on the wheel. Shifting and shuffling uses up brain power you need elsewhere.
At my local track you can stay in 3rd, this limits straight away speeds. Its much easier to nail the turn in points/speeds if you're not rushing up on corners. If you approach a 50mph corner at 65 mph it's easier to judge then 75. Did I also mention don't shuffle your hands.
If you're not completely overwhelmed to the point of hyperventilating I will introduce the concept of rotating the car via the fine art of trailing the brakes. Coming off the brakes smoothly is one of the most important concepts you'll ever learn.
It's simple as this; as you turn into the corner you start easing off the brakes at the same rate you wind in the steering. 90% brake 10 % steering then 80/20, 50/50 all the way to 95% steering 5% braking. You're just resting your foot on the brake to keep weight on the nose of the car so it keeps turning.
This is easier, safer and faster. Most newbies have a habit of popping off the brakes just as they enter a corner, this unloads the front end to the point of causing understeer, I want to eliminate this habit right away as it is a big reason why people go off the road especially as they advance. Either they understeer off or they stuff in a bunch off steering to counter the understeer on turn in and get snap oversteer mid corner.
Next I'll use a constant radius double apex corner and show simple throttle steering.
As we go past the first apex on steady throttle I'll tell you to slightly increase the throttle, which will make the car roll out towards the track edge, then slowly & slightly ease off which will make the car "rotate" into the second apex, then hold steady throttle to keep the car on that trajectory. Once we go past the second apex you can do the standard unwind the wheel roll into the throttle at the same rate exiting the corner.
Note we do this at 40-50% speed.
Many people will tell you that trail braking and throttle steering are advanced techniques that should be left for when you have more experience.
Here is why I disagree. If you start be steering the car from entrance to apex to exit like your street driving you will have to unlearn this. If you watch videos, be they Pros or a competent track day driver, you'll see that drivers turn the wheel twice per corner; once to turn in and once unwind the wheel exiting, the rest of the time you are using brake and throttle to put the car on a trajectory. This is the place you want to get to. If you are learning to play baseball, tennis or golf there is no "beginners swing" so my philosophy is learn the proper technique from the start.......even if you suck at it at first. (It's OK to suck at this because everyone did at first). It's also easier on the car.
Now with all that said; you are not going to master these techniques your first weekend, you will likely not even string together one good lap, you will be completely overwhelmed, it won't matter because you'll be a way better driver and most importantly have a blast.
Tom
