In reply to alfadriver :
My post made it sound like CF monocoque is bad, but you can achieve good results. I think that the problem is most people think it will be just like that FG boat they build a few years back. Building a good performing structure is a lot more complex.
1 - You need a lot of experience laying fabric before you get good. I know most FSAE teams completely mess up their first efforts. My old work place used to hire guys with experience building boats, but they all had that bad habit of applying too much epoxy because the part looks good after. But a composite piece with too much epoxy is weak. They wouldn't care about fiber alignment because they used to work with FG mat. And they had a tendency to cut the fabric to large to cut some back later, but they would get lazy. That could screw-up with the load pathways thru the part. I know I wouldn't feel confident trying to make a monocoque that my life would depend on.
2 - To help with the lay-up, you need to CNC cut your fabric. Because fabric tends to move (stretch, shift, etc.) when you cut it by hand, you often get misalignment or size issues.
3 - Tubes, beams, plates and honeycombs were getting better everyday and I am sure they are much better than they were. Since they are mass-produced, you take out the human element and improve quality. I would still like to make my own tests before using a product, but it was getting better. If you can think of a way of making a chassis using these elements, you could have something. We see a lot of trial in the bicycle and FSAE world. The issue is in joining the elements. I haven't seen anything that I really like yet.
4 - Engineers now know that you have to test the properties of the material you will be using before doing any calculations. Most fabrics "age" with time. Most FSAE teams build their monocoque using aged out material that is donated to them by aircraft manufacturers. The amount of epoxy (if you don't go pre-impregnated) will also greatly affect the strength. So building a test panel and verifying the results is a must.
5 - Finding an cheap source of autoclave time is a real hurdle. Most FSAE teams also have their autoclave time given by their sponsor aircraft manufacturer. Which I doubt they would for a small company or an individual building a race car.
6 - Since there isn't a way of fixing a bad part, you don't really care where the issue is, you just have to know if there is one. So testing the finished product is pretty easy. Either some strain gauges or simple torsional rigidity test of your finished chassis will quickly tell you how good it is.
7 - Even if you did everything right, you still have to accept a pretty big variation in the finished product. FSAE teams would get 20-25% variations in their results. You have to be ready to live with that.
It's been 10 years since I was involved in that world, so things might have changed. I am now a casual observer, so YMMV.
