volvoclearinghouse
volvoclearinghouse SuperDork
2/24/16 7:05 a.m.
hunting gears
ultraclyde
ultraclyde UltraDork
2/24/16 7:27 a.m.
So...a hunting ratio meshes the same teeth on every rotation, and a semi-hunting ratio requires multiple rotations before the same teeth meet again?
I get the concept, but that is the most nonsensical terminology I've heard in a long time. Seems completely backwards, even to make a little sense.
java230
java230 HalfDork
2/24/16 9:59 a.m.
TIL Hunting and semi hunting ratios!
volvoclearinghouse
3/1/16 6:55 a.m.
So....crap. Went to install the Trac-Lok last night and turns out they need longer bolts. With washers. I also need carrier bearings, but those are in stock at most autop parts stores.
The hard part is finding these bolts/ washers. I need them tonight. Can't use hardware from tractor supply- it needs to be the exact right part. Anyone know any speed shops in the Baltimore area where I could pick up these bolts/ washers?
RossD
RossD UltimaDork
3/1/16 7:08 a.m.
Ford dealership?
volvoclearinghouse
3/1/16 7:48 a.m.
I'll try. Worst case I'll have to get them overnighted from someplace.
volvoclearinghouse
3/1/16 10:06 a.m.
Fastenal actually had the exact perfect bolts. $17 for a pack of 25. Now we have 15 spares.
Anyone need a set of 10 Trac-Lok compatible ring gear bolts? Only $15!!
Lr4VWb8LLYdxt4x5mSW8F7fEK1gFvHIOUKiTXQPDkQ5y0qzyZEuzak1bEscb4v0J
