Hey guys,
I know this isnt a pick up forum by no means but they have all failed me. I have an '87 f-150 two wheel drive pickup. It has a 300 six, its fuel injected (this was the first year for the 6). I got the truck about 3 years ago as a present from my then girlfiriend, now wife. It runs great when its cold...but when it gets up to operating temperature it develps a slight miss (nothing bad enough to affect the running, just noticable when setting at a stop light or in traffic) and wont restart until it cools down. By accident I found that if i unhook the timing spout it will restart. (so in true grassroots colors I hooked up a toggle switch in the cab in case I killed it or something). When I pull the codes using a VOM it sends multiple electrical failure...
I have replaced the coil, multiple relays, distributor, halls effect device (pick up coil), TFI module...I think that is about it. I have the timing advanced about as far it can go and still run and it seems to start easier when hot but still not reliably. (unless the timing spout is unhooked)
any ideas??
