Petrolburner
Petrolburner HalfDork
10/11/15 4:31 p.m.
I'm insulating the Motovan. It's got additional dome lights built in. The rear door lamp was missing the cover, and it only worked when the rear door was open AND the other dome lights were on, either from another door being open our manual override. While insulating the rear door, I removed the light. None of my dome lights work now. I checked the fuse, called "illuminated entry module 5 amp" and that fuse was missing. Could not find any blown fuses. Put the rear door lamp back in the system and still no dice. No voltage at the rear door lamp wires either. It was just a red wire and the lamp was grounded to the door frame. Everything else is working. What next?
Petrolburner
10/12/15 1:32 a.m.
Still couldn't solve the problem or come up with anything else to trouble shoot. Pretty sure it's related to the original modification. Really hate to test the wall apart again.
Petrolburner
12/21/15 5:58 p.m.
Turns out it was a bad fuse. It looked good, but had no continuity.
7EKPrTYauMPMeUxvVZb9oddQCTcKiccUzFfiHmUPJdvjkPZZRdBszRUtiuDkBrbg
