Tyler H
Tyler H GRM+ Memberand Dork
1/17/12 4:50 p.m.
The built in check valve is bad in my old 535i's fuel pump, resulting in long cranking times. Otherwise, the fuel pump works well. Does anyone make a cheap in-line check valve. I hate to throw a $200 fuel pump on it for a $5 valve.
This should be a foot of new hose and 2 hose clamp fix.
Streetwiseguy SuperDork
1/17/12 5:23 p.m.
Have you checked to see if the valve is available separately from the pump? Typically, on Bosch external pumps it screws in to the outlet on the pump. I know Volvo sells them.
wearymicrobe
wearymicrobe HalfDork
1/17/12 5:44 p.m.
IF you cannot find one, most boast supply houses sell 3/8 male barb'd valves pretty cheap. Last one I bought was ~11$ works better then I ever thought.
wearymicrobe
1/17/12 5:45 p.m.
http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productId=1035222&catalogId=10001&langId=-1&storeId=11151&storeNum=50366&subdeptNum=50406&classNum=50407
Tyler H
1/17/12 6:00 p.m.
Streetwiseguy wrote: Have you checked to see if the valve is available separately from the pump? Typically, on Bosch external pumps it screws in to the outlet on the pump. I know Volvo sells them.
I'll look into it. I know the aftermarket pumps come this way, but I don't recall the stock one being serviceable.
jstand
jstand New Reader
1/17/12 6:32 p.m.
When my S10 had a problem with fuel draining back I put a check valve in line.
I was able to order the check valve, and compression fittings from McMaster for about $30.
Tyler H
1/17/12 8:40 p.m.
Off to check McMaster.
This whole condition could have been remedied if Motronic 1.0 primed the fuel pump when the key turns to 'on.' My new lawnmower does that.
If I don't find a check valve I like, a momentary switch wired to the fuel pump relay will also work.
Jlh8ZwGRM23n1aWuGKz1nUuYvZlJIm1tn6fsaajKwPawQ6HxbRhGaCLm29EfhpfD
