Mustang50
Mustang50 Reader
10/27/22 8:02 p.m.
I have a 2017 Lincoln MKC "SUV" that has flapper valves in the fuel filler tube.  In the past year I have had numerous check engine lights with the code for the fuel filler.   I have been told by the O"Reilly counter person to bang the fuel nozzle in and out of the neck rapidly when I get gas to shake any dirt loose that may be trapped in the flapper valve.   Does anyone have a solution to this problem?
alfadriver
alfadriver MegaDork
10/27/22 8:24 p.m.
If it's really debris, you can also use a good quality carb cleaner- which is combustible like fuel.  Use a clean poker to hold it open, and spray it clean.  I've not done this, BTW, just thinking about it.
sergio
sergio HalfDork
10/27/22 8:38 p.m.
Spray the flapper with WD40
kb58
kb58 UltraDork
10/27/22 8:43 p.m.
It wasn't mentioned, so be sure to always tighten the cap until it clicks, else the ECU thinks there's a leak.
alfadriver
alfadriver MegaDork
10/27/22 9:04 p.m.
There's no cap.
kb58
kb58 UltraDork
10/27/22 9:32 p.m.
Most recent cars monitor fuel tank pressure as part of the emissions system. I suggest adding a cap and seeing what happens. I feel like part of the story is missing here.
Cousin_Eddie (Forum Supporter)
Cousin_Eddie (Forum Supporter) Dork
10/27/22 9:38 p.m.
His car has no fuel cap and never had one. It's designed that way. He can't just go buy a cap and install it. Ford (and others) been doing it that way for a pretty good while now.
alfadriver
alfadriver MegaDork
10/27/22 9:47 p.m.
All of them have been monitoring for leaks since 1996, so... But "adding" a cap to a capless system isn't really an option, since the filler neck isn't designed to have one.
lmZ7NiaVs3262HcO2mG5NYbSQF4igoWvP12J0Ba24X53RnS4PAlM1sXcI9S6lB8h
