singledownloop
singledownloop Reader
5/6/17 9:02 p.m.
I removed the entire gas line from carb to tank on my 62 volvo pv544 today.It was damaged in numerous spots.What off the shelf options do I have for new gas line?
dean1484
5/6/17 9:07 p.m.
Nicopper. Will not rust but is softer so can be damaged by impact. But easy to bend. The real question is can you get it in a big enough size. It is typically sold in 25 foot roles around here so one roll should do you.
Dr. Hess
Dr. Hess MegaDork
5/7/17 8:16 a.m.
You can get whole rolls of solid fuel line for carb (low pressure) applications from Summit and Jegs. I'm using one for the return lines in the RAV and the Locost. Easy to work with, 3/8", if I recall, but I'm sure there are various sizes, and not very expensive.
NOHOME
NOHOME PowerDork
5/7/17 9:05 a.m.
Going full plastic with the Molvo.
Ln1XtEBzl3hv5CYo3gILNcebhKWdmaFpPoFv4kflAB12b0UKtrWPdKG8UONcwThS
