classicJackets
classicJackets Dork
3/6/20 11:12 a.m.
In reply to BoostedBrandon :
2012–2016 Buick LaCrosse 303 hp (226 kW; 307 PS) @ 6800 rpm 264 lb⋅ft (358 N⋅m) @ 5300 rpm
2013–2015 Cadillac ATS 321 hp (239 kW; 325 PS) @ 6800 rpm 274 lb⋅ft (371 N⋅m) @ 4800 rpm
2012–2014 Cadillac CTS 318 hp (237 kW; 322 PS) @ 6800 rpm 275 lb⋅ft (373 N⋅m) @ 4900 rpm
(2014 Wagon & Coupe only)
2014–2015 Cadillac CTS 321 hp (239 kW; 325 PS) @ 6800 rpm 275 lb⋅ft (373 N⋅m) @ 4900 rpm
(2014 Sedan only)
2012–2016 Cadillac SRX 308 hp (230 kW; 312 PS) @ 6800 rpm 265 lb⋅ft (359 N⋅m) @ 2400 rpm
2013–2019 Cadillac XTS 304 hp (227 kW; 308 PS) @ 6800 rpm 264 lb⋅ft (358 N⋅m) @ 5200 rpm
2012–2015 Chevrolet Camaro 323 hp (241 kW; 327 PS) @ 6800 rpm 278 lb⋅ft (377 N⋅m) @ 4800 rpm
2012–2017 Chevrolet Caprice PPV 301 hp (224 kW; 305 PS) @ 6700 rpm 265 lb⋅ft (359 N⋅m) @ 4800 rpm
2015–2016 Chevrolet Colorado 305 hp (227 kW; 309 PS) @ 6800 rpm 269 lb⋅ft (365 N⋅m) @ 4000 rpm
GMC Canyon
2013–2017 Chevrolet Equinox 301 hp (224 kW; 305 PS) @ 6500 rpm 272 lb⋅ft (369 N⋅m) @ 4800 rpm
2012–2013 Chevrolet Impala 302 hp (225 kW; 306 PS) @ 6500 rpm 262 lb⋅ft (355 N⋅m) @ 5300 rpm
2014–present Chevrolet Impala 305 hp (227 kW; 309 PS) @ 6500 rpm 262 lb⋅ft (355 N⋅m) @ 5300 rpm
2013–2017 GMC Terrain 301 hp (224 kW; 305 PS) @ 6500 rpm 272 lb⋅ft (369 N⋅m) @ 4800 rpm
Vigo
Vigo MegaDork
3/6/20 11:12 a.m.
A 32/36 is small on a 2.8 liter even if it only revs to 4500, but it will probably give the least drivability issues right out of the box. If you're willing to maybe have to mess with the carb a bit, i think the bigger ones will give better end results afterwards.
81cpcamaro
81cpcamaro Dork
3/6/20 11:17 a.m.
2013 & up Camaros, CTS and a couple others I believe have the LFX. EDIT: someone already answered it better.
67LS1, my 67 El Camino with a 1994 LT1 only weighted 102 lbs more than your car. It was 3362 lbs with heavy Soft 8 wheels that I had my R-comps on. It had a little bit more weight on the rear than yours, but I can't remember the numbers.
BoostedBrandon
BoostedBrandon SuperDork
3/6/20 2:27 p.m.
Oh, it's that engine.
67LS1
67LS1 Reader
3/6/20 11:54 p.m.
According to the base weights on GM Heritage site a 66 el Camino was 20 lbs heavier than a 66 Chevelle hardtop. 67 probably wasn't far off. I assume equipment specified would change that up or down.
I did go with 4 wheel discs, large front and rear sway bars, tubular control arms, and a whole lot of Dynamat. I'll bet if I had been more anal about it I could have easily broke the 3k barrier.
The LFX V6 is pretty light but the 6L50 trans is huge and heavy. I'm also running catalytic converters.
67LS1
67LS1 New Reader
1/29/21 10:45 a.m.
I made a max MPG run from a gas station near my shop on a loop of about 75 miles back to the same station.
Driving  like there was an egg on the gas pedal and on the highway 95% of the time I got 39 mpg. Still averaging just over 30 on normal everyday driving.
I probably need someone with an HP Tuner to adjust the trans shifting because between 60-65 mph the trans hunts some between 5th and 6th. Super annoying.
Sh4dow562
Sh4dow562
10/4/22 11:35 p.m.
In reply to wvumtnbkr :
Ikno this thread is old but just seen your post and noticed you mentioned putting a 3400 into a rx7. I had just got an rx8 shell and i have a impala with a lx9 3500 that someone t-boned me in a hit and run so the engine is still good and was thinking of putting that into the rx8 is there any tips you can give to make the RWD conversion and what wiring harness and ecu did you use just basic info.
Dusterbd13-michael
Dusterbd13-michael MegaDork
10/5/22 5:51 a.m.
I also did a 3400 swap. In a miata
Lx9 is vvt or non vvt?
Non vvt: i used sinister performance who hacked the 03 malibu ecm for me. Used a 2.2 s10 flywheel and clutch, 3800 camaro five speed. Had to fab accessories, headers, notch the oil pan, and flip the upper intake while deleting the egr.
gumby
gumby GRM+ Memberand Dork
10/5/22 7:11 a.m.
In reply to Sh4dow562 :
wvumtnbkr has a rx8 swap going too
racerfink
racerfink UberDork
10/5/22 10:26 a.m.
2012–2016Buick LaCrosse303 hp (226 kW; 307 PS) @ 6800 rpm264 lb⋅ft (358 N⋅m) @ 5300 rpm2013–2015Cadillac ATS321 hp (239 kW; 325 PS) @ 6800 rpm274 lb⋅ft (371 N⋅m) @ 4800 rpm2012–2014Cadillac CTS318 hp (237 kW; 322 PS) @ 6800 rpm275 lb⋅ft (373 N⋅m) @ 4900 rpm(2014 Wagon & Coupe only)2014–2015Cadillac CTS321 hp (239 kW; 325 PS) @ 6800 rpm275 lb⋅ft (373 N⋅m) @ 4900 rpm(2014 Sedan only)2012–2016Cadillac SRX308 hp (230 kW; 312 PS) @ 6800 rpm265 lb⋅ft (359 N⋅m) @ 2400 rpm2013–2019Cadillac XTS304 hp (227 kW; 308 PS) @ 6800 rpm264 lb⋅ft (358 N⋅m) @ 5200 rpm2012–2015Chevrolet Camaro323 hp (241 kW; 327 PS) @ 6800 rpm278 lb⋅ft (377 N⋅m) @ 4800 rpm2012–2017Chevrolet Caprice PPV301 hp (224 kW; 305 PS) @ 6700 rpm265 lb⋅ft (359 N⋅m) @ 4800 rpm2015–2016Chevrolet Colorado305 hp (227 kW; 309 PS) @ 6800 rpm269 lb⋅ft (365 N⋅m) @ 4000 rpmGMC Canyon2013–2017Chevrolet Equinox301 hp (224 kW; 305 PS) @ 6500 rpm272 lb⋅ft (369 N⋅m) @ 4800 rpm2012–2013Chevrolet Impala302 hp (225 kW; 306 PS) @ 6500 rpm262 lb⋅ft (355 N⋅m) @ 5300 rpm2014–presentChevrolet Impala305 hp (227 kW; 309 PS) @ 6500 rpm262 lb⋅ft (355 N⋅m) @ 5300 rpm2013–2017GMC Terrain301 hp (224 kW; 305 PS) @ 6500 rpm272 lb⋅ft (369 N⋅m) @ 4800 rpm
Strange that it doesn't list the 2016 to current LFX Camaro, with 335hp.
wvumtnbkr
10/5/22 11:51 a.m.
Thanks.  I need to update that thread....
It really depends on what your intent is.  If it is racecar, it's fairly straight forward.  If it is nice streetcar, it's a totally different animal!
I'm going for nice streetcar with ac and all the bells and whistles.
If you have specific questions, feel free to ask in the linked thread so we keep all the info in 1 place.
Thanks!
Gearheadotaku (Forum Supporter)
Gearheadotaku (Forum Supporter) GRM+ Memberand UltimaDork
10/5/22 3:31 p.m.
The 2016+ 335hp engine is the LGX
HRKhdMNqR2WnV1CdxOJABsm7MZzhx53eB9y7Mo7ANpRuQm66QxPIZUTd3YeUUaCo
