10/21/23 4:28 p.m.
Spin it, bring a battery, cables etc,, do a compression test if possible.   No way to pressure test a coolant system in a guy's garage; what else can be done to keep from throwing money away?
TurnerX19
TurnerX19 UberDork
10/21/23 4:46 p.m.
Old style Stant radiator pressure pump add a bunch of hoses and clamps, some dowels,assorted core plugs, and you can air pressure test the cooling system. Look at your engine and hoses to figure what you need.
j_tso
j_tso Dork
10/21/23 5:05 p.m.
You can get a cheap borescope that transmits to your phone to look into cylinders and other passages.
10/21/23 5:14 p.m.
porschenut
porschenut HalfDork
10/21/23 5:16 p.m.
Big crowbar to check end play on the crank
I always buy an engine knowing I am immediately going to tear it down to the crank and rebuild it.
NOHOME
NOHOME MegaDork
10/21/23 11:36 p.m.
leakdown test. Much better than compression and you dont need a battery to spin it,
Streetwiseguy MegaDork
10/22/23 12:19 a.m.
If it's the engine in the photo, as long as there's no rods hung out the side, it's worth it.
If you need it...
Catmaigne
Catmaigne New Reader
10/22/23 12:31 a.m.
If you can, pull the pan and look for bearing material, milky oil, etc.
lotusseven7 (Forum Supporter)
lotusseven7 (Forum Supporter) Dork
10/22/23 11:14 a.m.
Just finding one is a rarity and if you're lucky enough to be able to buy it, you buy it. Regardless of condition, if it's a complete engine, you load it up and consider yourself lucky. Anything beyond that is a bonus.
boulder_dweeb
boulder_dweeb Reader
10/22/23 1:19 p.m.
OK...what the hell is that motor. (Asking for a friend)
Rog
10/22/23 2:01 p.m.
Quite honestly, I'd yank the heads. It's easy enough on a flathead.  If he wants a nonrefundable deposit before you do, it's worth it to know if this block is also cracked or poorly repaired sometime in the last 80 years.
You already have a good rotating assembly and everything else, right?  Or at least enough bits to come up with one good one.  So all that matters is block integrity.
NOHOME
NOHOME MegaDork
10/22/23 4:19 p.m.
Rog
Amen.
The Delco Remy distributor suggest circa 1930 GM, but not aware of any GM flatheads personally.
10/22/23 4:49 p.m.
In reply to NOHOME :
Caddy made flatheads up into the 1940s.
Also
Curtis73 (Forum Supporter)
10/22/23 5:21 p.m.
Also
Does look like a Caddy/LaSalle, doesn't it?
Scott_H
Scott_H Reader
10/22/23 5:32 p.m.
Are you wanting to build a sidewalk?  There are easier ways but I bet not as flat.
NermalSnert (Forum Supporter)
NermalSnert (Forum Supporter) HalfDork
10/22/23 7:15 p.m.
Is that olive drab green? Military use?
10/22/23 8:00 p.m.
In reply to NermalSnert (Forum Supporter) :
The all original '40 Cadillac V8 that I did some service work to was painted that color, although apparently some military vehicles did get these engines.  It wasn't like GM was going to be putting any into cars for a while, after all.
10/23/23 9:03 a.m.
In reply to boulder_dweeb :
1937 Cadillac 322 flattie, 3.375 bore and a VERY long stroke.
Recon1342
Recon1342 SuperDork
10/23/23 10:40 a.m.
Rog
Cadillac 322 Flathead
MiniDave
MiniDave HalfDork
10/23/23 1:24 p.m.
Are  you hoping to just swap this in - in place of the other one - and have a running driving car?
I always prefer to rebuild what I have, so I then know what I have rather than taking a chance on someone else's work.
If it's priced well, I'd go for it but plan on rebuilding mine anyway.
With a battery - if there's oil in the crankcase and a starter motor, with a few jump leads you can fire it up right there in the driveway.
10/25/23 10:38 a.m.
The one above didn't work out.   Another one 300 miles closer to home.  This one is a 1941 346 c.i. in  lieu of the 322; same block just punched out a bit by factory.  Sounds like it's got all the stuff, Pertronix runs on 12V?  So maybe it's already converted to 12.  I have good, magged and milled 322 heads which will increase the compression from 6.5 : 1 to something more.
Thoughts?
Recon1342
Recon1342 SuperDork
10/25/23 12:39 p.m.
In reply to 914Driver :
If it's in good shape, jump on it. The 346 seems to have more documentation available, so it may be a bit easier to work with.
Stampie
10/25/23 12:59 p.m.
I'll drop this right here.
https://www.modifiedcadillac.org/documents/
Make sure you check out 1944 and the Shop Manuals.
MiniDave
MiniDave HalfDork
10/25/23 5:16 p.m.
$2500 seems like a lot to me for an engine with unknown condition......is the other one you already have not rebuildable?
LmPPsbDQOf6DYVaOmarY9TTMJsNZctKvgY5ZCpLWfFZVCVass7FIoTnzGju4dXZg
