oldtin
oldtin UltraDork
6/29/13 6:11 p.m.
tpwalsh
tpwalsh Reader
6/29/13 6:38 p.m.
That's awesome, and yet.. a E36 M3 ton of work!
6/29/13 6:41 p.m.
now -that- is how you bend a pipe
bearmtnmartin
bearmtnmartin GRM+ Memberand HalfDork
6/29/13 6:54 p.m.
There are easier ways. I did this whole cage with sand, duct tape, a torch and a vise.
fasted58
fasted58 PowerDork
6/29/13 7:17 p.m.
Old pipe fitting trick
E36 M3load of work when a few bills at a cut rate exhaust shop would do
not bad if ya can do it tho
jere
jere Reader
6/30/13 1:51 a.m.
bearmtnmartin wrote: There are easier ways. I did this whole cage with sand, duct tape, a torch and a vise.
Whoa I've heard of this with exhaust but a cage Does the heat mess with the temper of the steel? What tubing did you use?
Kenny_McCormic
Kenny_McCormic Dork
6/30/13 2:00 a.m.
What is this "free time"? Last time I needed a bend I bought a 45* crush bend and put some cuts in it to bend it farther, then welded them up. This is ok when its a 1.116 liter engine with a 2" exhaust.
novaderrik
novaderrik UberDork
6/30/13 4:12 a.m.
2 things:
1) is it a rule that every video like this never involves using the proper wrench? it's always a crescent wrench or vise grip, and never a simple 3/4" wrench..
2) why did they put the fire so damn far from their bending wheel fixture thingie? it looked like a 50 foot run just to get from the fire to the bender...
bearmtnmartin
7/1/13 12:35 a.m.
It's 1.5 inch DOM. Almost no heat at all. Just enough to help the outside bend a bit, and then only on the very tight bends like the halo. I have kinked and flattened a lot of pipe figuring it out.
Dr. Hess
Dr. Hess UltimaDork
7/1/13 8:24 a.m.
Nice work, Martin. Sand bending is a serious art form. I experimented with it using 2.5" 304. My conclusions were that I could learn how to do it very well if I could go through about $10K worth of tubing first. I had the hoop for the Locost bent at a local dirt track shop.
Gearheadotaku
Gearheadotaku GRM+ Memberand UltraDork
7/1/13 8:55 a.m.
"Building a custom exhaust on a challenge budget..."
bearmtnmartin
7/1/13 10:13 a.m.
If I do another cage I will be buying a bender. It makes a big job much easier.
cdo1GlfCvaEXX3odeQi5j9FbJhQC56YV8AMCub3MnuOcNGmgHheKaPZkICGqzBdf
