steronz
steronz Reader
10/3/13 10:23 a.m.
I've decided we need some more layback in our chumpcar. It's a crappy Sparco Sprint mounted to the stock rails, which are mounted to the floor.
We had the idea to get a length of 1.5" square tube and some longer bolts for the front, drill 2 holes all the way through the tube and just use it as a big spacer. Would that pass tech?
What about the same as above except we use a 2x4?
DaveEstey
DaveEstey UltraDork
10/3/13 11:13 a.m.
square tube would likely be fine. Be even more fine if you weld it to the floor in a few places.
Don't do the 2x4. If it's not a Morgan wood doesn't belong in a car.
turboswede
turboswede GRM+ Memberand PowerDork
10/3/13 11:16 a.m.
I second the weld it in.
Otherwise if should work.
steronz
steronz Reader
10/3/13 11:25 a.m.
Weld-in it is. Thanks guys.
sOobeBoFlnKLPsMMQsds6gSnxRwxTRYS4O4QKlYkxTgogVwLEngfDzLc165cLFZS
