Some time off, but considering the idea of turboing the 1.5l in my Mazda2, vs just swapping a 2.5l MZR with an 07-09 Mazda3 5spd(G35M-R). Good for a relatively easy 200 crank horsepower with minor bolt ons and tune.
Part of that is figuring out what to expect from a turbo setup. Bonus is fun turbo spooly whoosh noises
I previously made a VE calculator in Excel for grins, and I've since added a few more tables to estimate airflow under boost. Frankly I think it will slightly underestimate to some degree, because under pressure it should make up for lower VE with atmospheric pressure, but regardless here are the numbers from my car, based on logged data through Mazdaedit:
Something that will actually spool up and not feel terrible at 6psi on stock internals would be great to just get a system together and the hard parts and tuning established. Long term goals would be to build another long block with forged pistons and stronger rods(notice the bore is the same as a B6T Custom rods needed for sure). Pressure could be whatever it needs to be. I frankly don't think more than about 250whp would even be of much use, and honestly that's about what I'm expecting the transmission to break around, if not closer to 200whp. There is another fellow in Greece who's turbo'd one of these, but he broke teeth off of 3rd gear... which I really shouldn't be getting into.
This is for autocross use(SMF), so pretty quick but controllable spool would be ideal. A faster spool can be controlled by a good boost controller/Megasquirt/etc... but if it's like a light switch when the boost hits, then a slightly bigger one probably could have been chosen to give either more potential headroom, or for lower intake charge temps, etc.
It sounds small, but the compressor map looks REALLY good for a Garrett GT2252 for just about anywhere from 6-18psi. FWIW I'd probably choose the 0.67 A/R exhaust housing. GT2252
And then the GT2854R also looks nice. Same with the 2554R. GT2854R
The question is with the estimated limitations of the transmission, is the 2252 not even at risk of being maxed out(tune power down low with TPS based boost control) and I'm over thinking it? Or is something bigger a good idea?
I can read a compressor map and know if something is at least safe(surge line and efficiency-wise), but the turbine maps I know are essentially useless.
I THINK something that gets positive pressure around 3000rpms, and maybe 8-10psi by 4000rpms would be about right for reasonable response without giving up anything up top if trying to push the turbo size... I'm trying to figure out bigger vs smaller turbo, for lower power levels is there a reason to choose one or the other?
Would one or the other be better suited to HPDE use?
FWIW the Mazda2 1.5l is a low revving(100hp at 6000rpm, 98ft-lb at 4000rpms, stock redline of 6200) 4cyl. With the rev limit raised to 7200rpm, there is basically no power above stock redline, it drops kinda quickly... but while N/A it at least makes sense because the 1-2 shift is so badly spaced out.
WWGRMD?
