Luke
Luke SuperDork
4/6/10 2:17 a.m.
I finally got some time to change the oil on the relatively new-to-me BMW. The sump plug bolt came loose without too much force (despite whoever changed the oil last not using a washer), and I began to thread it out by hand. However, about 2/3 of the way out it gets stuck tight. I don't want to force it and risk damaging the thread. Any ideas?
ZOO
ZOO GRM+ Memberand Dork
4/6/10 5:13 a.m.
Little bit of heat from a hair dryer?
DrBoost
DrBoost Dork
4/6/10 6:54 a.m.
I'd just back it out and be prepared to repair the pan threads.
914Driver SuperDork
4/6/10 7:52 a.m.
NAPA sells a repair kit for that. Even I can use it well.
Dan
carzan
carzan Reader
4/6/10 8:39 a.m.
Is it half-stuck? Or is it half-loose?
I'm thinking you have little choice but to go ahead and remove it. If it is very difficult to remove, I would imagine the threads are already damaged. Just have the repair kit on standby.
gjz30075
gjz30075 Reader
4/6/10 10:46 a.m.
Being stuck tight by hand removal isn't a big deal. Try a socket and you'll probably find it's a fairly normal 'tension' upon removal.
As Carzan indicated, you have no choice now but to continue. I think you'll find the threads fine. Perhaps the PO used some locktite or rtv because he lost the washer.
Luke
Luke SuperDork
4/6/10 10:37 p.m.
Quick update for those of you losing sleep over my sump-bolt predicament .
All is fine, the bolt came out okay etc. Thanks
DaveEstey
DaveEstey New Reader
4/6/10 10:56 p.m.
phew no I can finally rest
BobOfTheFuture
BobOfTheFuture Reader
4/7/10 2:15 a.m.
okay! goin to bed...
RedS13Coupe
RedS13Coupe Reader
4/7/10 2:38 a.m.
gjz30075 wrote: Being stuck tight by hand removal isn't a big deal. Try a socket and you'll probably find it's a fairly normal 'tension' upon removal. As Carzan indicated, you have no choice now but to continue. I think you'll find the threads fine. Perhaps the PO used some locktite or rtv because he lost the washer.
Yup. Just takes a little bit of grit in the threads to make it not hand tight (lose?) anymore... Clean threads are better, but unless it feels stuck to your wrench too is likely not a big deal.
aTLvD3vGCaSmv0LEEB7SKUxHHqR2ThUMvlcmHhdv1Q9moR45lF8AuzAs11NSiQAd
