pirate
pirate HalfDork
12/21/20 2:16 p.m.
I have a 1 Ton Harbor Freight Engine Hoist that I don’t use a lot. However pulled it out to use and found the boom slowly lowers even without any load. It is not leaking externally so assume it may be a internal “O” Ring. Anyone have this problem and if so how did you fix it. Thanks
TJL (Forum Supporter)
TJL (Forum Supporter) HalfDork
12/21/20 2:33 p.m.
I have the 2 ton one. I quickly replaced the stock cylinder with the "air over hydraulic" version, so now my air compressor does the work. The original cyl had a bad leak, it would pee all over the place. The air op one has been perfect.
03Panther
03Panther SuperDork
12/21/20 2:37 p.m.
I have the one ton. Its been abused and neglected. Surprisingly, mine does not have this problem, although I've seen others of various quality levels with it.
I haven't sprung for the air over cylinder like TJL, but a friend did, and it is the way to go.
This is the correct answer.
eastsideTim
eastsideTim PowerDork
12/21/20 3:41 p.m.
I’ve just fixed the issue by picking up a replacement HF hydraulic cylinder.  I figure as long as they fail slowly, I’ll be safe using them and replacing them as needed.
secretariata (Forum Supporter)
secretariata (Forum Supporter) GRM+ Memberand SuperDork
12/21/20 3:59 p.m.
I have had the 2 ton for about 20 years (most of which it has sat in the corner growing cobwebs & dust) & used it for the first time in probably 10 years on Saturday with no issues.  Apparently the older ones have better seals?
Stampie (FS)
12/21/20 4:35 p.m.
We had an o ring fail on ours about a year ago.  Replaced that and it was good for a while until it did the leak down under load thing.  Last week we replaced the cylinder with a new one for like $60.
irish44j (Forum Supporter)
12/21/20 7:33 p.m.
I've had the 2-ton for about 6-7 years now. Used it a couple dozen times, and it lives outside under a tarp. Never had any issues with it leaking or losing pressure. YMMV.
kb58
kb58 SuperDork
12/22/20 10:49 a.m.
It could always be worse - not mine, and this probably didn't end well.
LsUCAZ1rVM7jDmoRVyBi9aFA2KoWoOKSO90fH1Y1Q0XMqjVPaa54sZSTbEA5VVmQ
