docwyte
docwyte UberDork
2/13/20 10:25 p.m.
Specifically, this one...
https://www.harborfreight.com/merchandising-promotions/new/6-in-75-amp-dual-action-random-orbit-polisher-56367.html
Figure I'd pair it with Adams Polishes pads and compounds...
old_
old_ HalfDork
2/13/20 10:31 p.m.
Idk but here's a coupon
irish44j
irish44j MegaDork
2/13/20 10:48 p.m.
I have the old version (without the nice front handle). Seems to work fine, hasn't broken.
aircooled
aircooled MegaDork
2/13/20 11:47 p.m.
They have a variety of pads now also.
Cactus
Cactus Reader
2/14/20 6:06 a.m.
I've used their pads on a Griot's polisher. Griot's pads are nicer, but if you're gonna risk tearing them up on a rusty patch, might as well go with the cheapy. And then make sure you're not dragging rust particles over good paint.
engiekev
engiekev Reader
2/14/20 7:41 a.m.
I've used the old version on several full car polishes, works great.  You can use the HF pads if you cut the outer edge so that the velcro part is the same size as the hook/loop part on the polisher, if you don't the HF pads have overlap and will curl over and cause issues.
Tom_Spangler
Tom_Spangler GRM+ Memberand PowerDork
2/14/20 7:55 a.m.
It probably won't last as long and will almost certainly be louder than a nicer one, but it'll get the job done, especially if it's something you only need occasionally.
therieldeal
therieldeal Reader
2/14/20 9:16 a.m.
I also have the "older" chicago electric one, seems to work just fine.  I really should use it more often, my cars are looking a bit dull...
Tony Sestito
Tony Sestito PowerDork
2/14/20 9:21 a.m.
I have the Chicago Electric one as well. Works great! Just use good pads and chemicals and you'll get great results.
Wicked93gs
Wicked93gs New Reader
2/14/20 9:22 a.m.
My experience with most harbor freight tools is that they do the job fine...just not as well as better known names....except their drill bits...they just suck.
ChrisLS8
ChrisLS8 New Reader
2/14/20 11:54 a.m.
I like mine. It's no rupes but it has made some stunning corrections with proper technique and materials.
I have the older Platinum and it seems that is favored over the newer Bauer. I swapped the backing plate out cause it ate the outter edge of pads up
docwyte
docwyte UberDork
2/14/20 2:50 p.m.
Is it worth spending the money for a nicer one from Griots or Adams Polishes?  They're closer to $200, which I'm happy to spend if the quality difference is there...
Tony Sestito
2/14/20 3:03 p.m.
In reply to docwyte :
Honestly, probably not. It wouldn't surprise me if they were made in the same manufacturing facility! I would just make sure you are using quality pads and polishes. I've done a ton of cars with my HF random orbit and it hasn't turned into a hammer yet.
Strike_Zero
Strike_Zero UltraDork
2/14/20 4:58 p.m.
I need to polish up a few cars. I guess I need to add this to the shopping list.
Where do you recommend I get the pads from?
ChrisLS8
ChrisLS8 New Reader
2/14/20 5:35 p.m.
In reply to Strike_Zero :
Pads use lake country. I stick with Pinnacle or Meguiars for polishes and compounds
Toyman01
2/14/20 5:35 p.m.
What he said.
93gsxturbo
93gsxturbo SuperDork
2/14/20 6:12 p.m.
I have the older one, Chemical Guys pads asst from Amazon and some Meguiars polish and do OK
docwyte
docwyte UberDork
2/14/20 6:32 p.m.
Adams Polishes is local to me and supports multiple car clubs I'm in, so I'm probably going to use their pads/polishes/clay bar/foam cannon etc
docwyte
docwyte UberDork
2/16/20 1:30 p.m.
Returned a crappy HF led light yesterday and wanted to use the store credit for the polisher.  Well, they're all out of stock in basically all their Denver area stores plus the warehouse.
Was going to order it online but I might as well wait until spring, not gonna use it for awhile the way the snow keeps rolling in every week here.
conesare2seconds
conesare2seconds Dork
2/22/20 10:40 a.m.
There is a YouTube channel by  guy in Dallas who details and does paint correction.  He occasionally does product comparisons and the short of it is the HF is a nice piece, just change the backing plate. Can confirm, the HF plate is a bit wobbly but I sourced a nice one from Amazon for cheap. Problem solved.
docwyte
docwyte UberDork
2/23/20 9:08 a.m.
In reply to conesare2seconds :
At that point tho the price point is about the same as the Griots Garage one.  Which is better quality period and basically has a lifetime warranty.  I just got an email from Hagerty saying I get 15% off Griots stuff, so I think I'm just going to buy theirs
psAcIreiMzD4xakCUiqiTqVRTXllbXOWnyQMNzK2HIj7J5W4qwhdCzAFbhYG2iMj
