octavious
octavious Dork
3/18/20 12:14 p.m.
So I pulled this, and it threw a CEL and the radio won't turn on. And the idle is off.
upon further inspection that is hooked to this
With the last two wires being wired into the left connector here not a great pic but you can kind of see the electric tape. I use wired loosely, as their looks like someone hand twisted the wires together and put electric tape on them.
Robbie
Robbie MegaDork
3/18/20 12:18 p.m.
Was that an hour meter?
Either way, I'd start by looking at what those two wires on the ecu are supposed to go to on a wiring diagram.
octavious
octavious Dork
3/18/20 12:20 p.m.
And inside of the black box is this
no names of anything anywhere. The black box was on the inside of the inner fender held on with Velcro
itsarebuild
itsarebuild GRM+ Memberand Dork
3/18/20 12:41 p.m.
Big brother is watching you.....
captdownshift
captdownshift GRM+ Memberand UltimaDork
3/18/20 12:50 p.m.
Alert alert Octavious has breached quarantine measures alert alert
octavious
octavious Dork
3/18/20 12:54 p.m.
I needed that laugh.
here is all of it out of the car and connections at the ECU connected.
Fueled by Caffeine
Fueled by Caffeine MegaDork
3/18/20 1:10 p.m.
Is that an alcohol interlock?
Stampie
Stampie GRM+ Memberand UltimaDork
3/18/20 1:16 p.m.
In reply to Fueled by Caffeine :
So the whole "I bought a Miata" thing was a ruse so we'd help him defeat his DUI interlock!
octavious
octavious Dork
3/18/20 1:21 p.m.
CEL was a blown ROOM fuse.
Starts runs fine. But now the idle is hunting while sitting stopped.
3/18/20 1:23 p.m.
I see a connection for MAP on that circuit board. Get me an indication of the pins at the ecu, I'll see what I can decipher.
Floating Doc
Floating Doc GRM+ Memberand UltraDork
3/18/20 1:25 p.m.
octavious
octavious Dork
3/18/20 1:32 p.m.
Just got back from getting gas. It runs and drives fine. Sitting stopped the idle hunts for a second between 350-500ish (it only has 7 dashes between 0-1).  After a second or two it idles right at 450.
@keith, well whatever it is, it wasn't connected correctly. It had one wire in the engine bay near the fuse box not connected to anything. It was just there.
I ran it until the fuel light came on yesterday. And then my wife took it out. Could I have run it too low and it's got some gunk in the injectors?
Olemiss540
Olemiss540 Reader
3/18/20 1:36 p.m.
Guessing Brutus put it in your car while you were sleeping to track your whereabouts.
Romans are a smart bunch.
RG9qudngtbGoGGH7aishzHTmQKmGiJd3rFApOYeyInwGugjkAFWclXUAb8NgYYwh
