8/11/16 3:09 p.m.
These are for a German made trailer and the common 2 inch ones just fall off. I found some but refuse to pay $16 shipping on a $2 item that weighs just ounces. 52mm = 2.047 inches.
These things but the less elaborate stamped tin is just fine.
BrokenYugo
BrokenYugo UltimaDork
8/11/16 4:16 p.m.
Seems it's easier to buy a pair of Bearing Buddies in that size than regular stamped caps. I'd be looking at older German and Japanese stuff. Maybe just go to the pick and pull with a set of calipers.
Hal
Hal UltraDork
8/11/16 6:06 p.m.
I've done it two ways:
  1. Get a strip of appropiate thickness sheetmetal, wrap it around and spot weld.
  2. Find a bead roller that fits and roll a bead around it. That usually stretches the metal enough to make it fit.
8/11/16 6:16 p.m.
Not my German made sailplane trailer, the owner's just befuddled with the shipping fees.
Contacted a brake shoe manufacturer in Ohio who keeps nothing in stock, but subs it to a dealer in Wisconsin. I called, they're closed for two weeks; perhaps they also carry the caps. Drum brake shoes are 50mm wide X 200mm drum if you know a hook up.
Thanks for the help, Dan
BrokenYugo
8/11/16 6:25 p.m.
If the brakes also need rebuilt, it might not be an awful idea (especially in the long haul) to swap in a standard axle with cheap readily available parts.
oldopelguy
oldopelguy UltraDork
8/11/16 6:50 p.m.
Regular cap plus local muffler shop or your harbor freight exhaust expander should work.
Or, depending on how much of the axle shaft sticks out, a soft plug.
Or, for a permanent temporary fix a pair of hose clamps per side and a rubber plumbing cap.
motomoron
motomoron SuperDork
8/12/16 10:29 p.m.
Kramer
Kramer Dork
8/13/16 3:50 p.m.
Dorman 13977 available at any parts store is 2.07". Probably close enough.
dimarra
dimarra Dork
8/13/16 3:52 p.m.
What if you used an exhaust pipe expander on the 2" ones?
7sRAQ3X9jmGmgpzJduW2COcw50BiEcPdHdRPGCRPQfX4jtaHDrPBhLykYiaLeflz
