Don49 (Forum Supporter)
Don49 (Forum Supporter) Dork
4/5/21 7:53 p.m.
Looking at that video, once you cut the roof out, you can use the existing roof and frame u=it up the the height you want. I would definitely cut the opening behind the seats  as that will help with structural strength.  I.m looking forward to seeing the build.
4/5/21 7:53 p.m.
Looking at that video, once you cut the roof out, you can use the existing roof and frame it up the the height you want. I would definitely cut the opening behind the seats  as that will help with structural strength.  I.m looking forward to seeing the build.
In reply to Don49 (Forum Supporter) :
There's a factory headliner that stops about right in line with the back of the seats/side door opening. I'm going to cut off the roof from there rearward. Although I'm going to cut it lower/closer to the edge than that vid. Rather than cut off the roof bows like they do, my plan is to drill out the spot welds & remove the entire bow. That'll leave a flat(ish) ledge that I can weld brackets to & attach the new top to.
o3FbzNdU4TZKsTHmLPjXalVbMdO2UMZ3ki45qN3t2Giq4KOwgTcTVuaRyXl82srq
