goodtimegator
goodtimegator New Reader
5/6/11 3:22 p.m.
Got a 2000 Miata 1.8 a/t a/c. Bought it 12/10. bad belt squeal in the a.m., at noon, and p.m. Squeals for about a hundred yards down the road then stops Specmiata racer and friend said " Put Mazda belts on it, don't fool around with aftermarket belts...and don't use any belt dressing!" So I did what he said to do.Squealing was gone for four days-then back just as loud as before So I went behind Specmiata man's back and put dressing on it. Have to do that every 2 to 3 days I'd heard Goodyear Gatorback belts would solve the problem, but I thought I'd try the Grassroots nation first! What do you folks think? Thanks!!!
John Brown
5/6/11 4:02 p.m.
Does the squeal look like this?
Capt Slow
Capt Slow Dork
5/6/11 4:07 p.m.
moar tension on the belts?
EricM
EricM Dork
5/6/11 4:09 p.m.
Sounds Belt related to me.
turboHLS30
turboHLS30 Reader
5/6/11 4:13 p.m.
Maybe one of the pulleys?
Xceler8x
Xceler8x GRM+ Memberand SuperDork
5/6/11 4:57 p.m.
John Brown wrote: Does the squeal look like this?
That's F'in funny.
"OH HEEEEEEeeeeeeeeeyyyyyyy! EEEEEEEEEEEEEEEEEE!"
Toyman01
Toyman01 GRM+ Memberand SuperDork
5/6/11 5:07 p.m.
I vote worn pulley. The belt is probably bottoming in the pulley before the Vs make contact. It will happen on a micro v as well as a standard v. If it only does it with the A/C on I would start there. Otherwise look at the alternator.
Keith
5/6/11 5:16 p.m.
The alternator runs off a separate belt from the ac/ps. So I'd start by removing the latter belt and see if the problem goes away. That'll help you isolate the problem area.
Kramer
Kramer HalfDork
5/6/11 10:17 p.m.
Your pullies are gummed up with rubber, and the belt dressing will just make it worse. Remove the belts, and put a naptha-soaked rag on the pulley for a while. Then use a wire brush to clean the pulley really well. This is the best fix possible.
motomoron
motomoron HalfDork
5/6/11 10:33 p.m.
Kramer wrote: Your pullies are gummed up with rubber, and the belt dressing will just make it worse. Remove the belts, and put a naptha-soaked rag on the pulley for a while. Then use a wire brush to clean the pulley really well. This is the best fix possible.
Actually, the best fix is to get ~someone else~ to remove the belts, and put a naptha-soaked rag on the pulley for a while. Then use a wire brush to clean the pulley really well.
White_and_Nerdy
White_and_Nerdy Reader
5/6/11 10:48 p.m.
The new belts might've stretched a little, and the tension needs to be reset, a.k.a. tightened a little. The same thing happened when I replaced the belts on my SE-R a few weeks ago. A little more tension after a few days, and I haven't heard a squeak since.
PeAB1EqvSVVRYuo9dtzXXFoOTsj6ibtFlBXxDEmGsfDfJb5FZr8rP5z3DjF6IRqt
