93EXCivic
93EXCivic SuperDork
4/1/11 12:32 p.m.
My Civic is making a super high pitch squealing noise and I can't figure out what it is. I am 99% sure it isn't in the engine or transmission because it doesn't make the noise when the engine is running and it will make the noise when the car is rolling and the clutch pedal is depressed. I don't think it is that new brake pads are needed because it makes the noise even when not braking.
mndsm
mndsm SuperDork
4/1/11 12:33 p.m.
Throwout bearing?
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
4/1/11 12:40 p.m.
Wait... when the engine is running, it doesn't make the noise?
dculberson
dculberson Reader
4/1/11 12:41 p.m.
That's my vote. Does it go away if the car is in neutral with the clutch pedal up? (Not depressed.)
Edit: Oh, crap, never mind. Squealing when it's not running but being pushed? And the clutch is depressed? Got to be brakes or wheel bearings, right? Something that's moving when the engine and transmission aren't.
poopshovel
poopshovel SuperDork
4/1/11 12:44 p.m.
Wheel bearing would be my first guess. Only happens when the car is moving, right? Coming from front or rear?
purplepeopleeater
purplepeopleeater Reader
4/1/11 12:56 p.m.
Brake warning sensors?
93EXCivic
93EXCivic SuperDork
4/4/11 10:14 a.m.
I am pretty sure it is something with the heating system. It did it for the first time while sitting still the other day. And since it has warmed up I haven't used the heat and it hasn't done it since.
16vCorey
16vCorey SuperDork
4/4/11 1:26 p.m.
Blower motor?
mndsm
mndsm SuperDork
4/4/11 1:29 p.m.
Could be a bad accessory pulley too, only squeals under load, which would be increased while the car is moving along.
poopshovel
4/12/11 11:52 a.m.
93EXCivic wrote: I am pretty sure it is something with the heating system. It did it for the first time while sitting still the other day. And since it has warmed up I haven't used the heat and it hasn't done it since.
Any news? Have you tried kicking the fan off when the noise starts? If it was doing it more often when the car is sitting still, I might guess cooling fan. When my integra's started crapping out, it was the worst sound I'd ever heard.
EXmxZbCaz5fMrnowYWOYeiId9og4oSf6dwjunvqLH7kysdbzTPwNjLnVg9aYLDeD
