tuna55
tuna55 UltimaDork
6/1/15 12:40 p.m.
gearheadmb wrote:
G_Body_Man wrote: I guess that in a year or two, it will be TH-350 time.
Or consider the 700r4. Its basically a th350 with an overdrive. Should be pretty easy. I think they are a little longer, so you would need a shorter driveshaft and a different crossmember, but that stuff should be easy to find. Then with the OD you can swap to some deeper gears, which I think you talked about on here before, correct?
200-R4, better ratios than the 700-R4.
6/1/15 12:45 p.m.
yamaha wrote:
G_Body_Man wrote:
N Sperlo wrote: I'm really curious about why and how your mechanic was checking your transmission fluid.
Whelp, it was fresh off the trailer, and he was giving it the once over. He pulls the trans dipstick, wipes it on his fingers, sniffs it, and says that someone put motor oil in the ATF.
Isn't atf pretty much just 5 or 10 weight oil?
It's very different from engine oil...it usually contains wax for one thing. Here's a BITOG thread on the topic:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=997755
iceracer
iceracer PowerDork
6/1/15 12:56 p.m.
ATF is probably more akin to hydraulic fluid than motor oil.
yamaha
yamaha MegaDork
6/1/15 1:06 p.m.
Gotcha.
G_Body_Man
G_Body_Man HalfDork
6/1/15 1:17 p.m.
It's very different from engine oil...it usually contains wax for one thing. Here's a BITOG thread on the topic: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=997755
I was wondering how he could tell. Maybe the feel and consistency of it wasn't right. Thankfully coolant wasn't poured in the trans reservoir.
Kenny_McCormic
Kenny_McCormic PowerDork
6/1/15 1:18 p.m.
I'm not sure how you can ascertain that from pulling a dipstick out and sniffing it, but whatever, we'll go with it.
Won't hurt anything, might make it shift a little firmer (good thing) come to think of it, motor oil not having various friction modifiers present in dex/merc. Viscosity increase is probably a non negative as well. If it really bothers you, do a pan drop and fill it back up with Valvoline maxlife.
G_Body_Man
G_Body_Man HalfDork
6/1/15 1:34 p.m.
In reply to Kenny_McCormic:
I'll probably keep it as-is, until I can buy a 200-4r and a new gauge cluster.
Kenny_McCormic
6/1/15 2:31 p.m.
What do you have now? 200C?
Zomby Woof
Zomby Woof PowerDork
6/1/15 3:00 p.m.
SVreX wrote: K-Y Jelly makes poor gear lube.
But it works in the rearend
dropstep
dropstep Reader
6/1/15 6:33 p.m.
we got an extra 6 months of use out of an aode courtesy of 2 quarts of 20w50.
G_Body_Man
G_Body_Man HalfDork
6/2/15 9:32 a.m.
TH250-C
Trans_Maro
Trans_Maro UberDork
6/2/15 9:56 a.m.
A small can of brake fluid in the ATF will stop the leaks and make the clutches grab well enough to get the dealer to take a clapped out minivan on trade.
Or so I'm told...
z7XVojZwmA9vdMBtzaQpZxSbA9Pxe8UJfY9LMCCkIXBnoBDAezuzy0BuqHNTktNs
