Wife's 2014 Sonic LTZ 1.4T
It's been a generally good car with a few pimples - I've put no money in it in 8 years, but it's been doing some funny things recently. I'd like to bounce this off you guys, Nick and Pete especially.
I don't know if this is related but it may be. About 3 years ago it, twice while driving, kicked the cruise off, all the dash lights flashed and she lost most power. it eventually died and restarted. Code was P16F3 - Control Module Redundant. Shortly after I (unrelated) replaced the battery and the problem never came back. I wondered if it was possibly a short in the battery or a bad connection.
Recently two things started happening. The cruise enable won't stay on after the car is shut off, so the cruise needs to be enabled every on/off cycle now, unless it's a quick off/on. Turning the key to start the car, you have to turn it all the way til it stops and there's a fraction of a second delay before it starts turning over.
Then last week I was driving it and the check engine light comes on, but no code. I clear it, shut the car off then on restart, it's running rough, the dash is a Christmas tree, and the tach's not working, and it sets codes 262b, 0068, 0641, 0651, 697, 06a3, 2227, 0068. I think it also had code 42 at some point. I cleared everything, tried to start it again, crank and no start. I pull the cables, all the wires attached to them, all the grounds, the ECU plugs, ABS plug, I inspect (don't see anything), and I clean everything. It started up and ran fine for a few hours then I got the hard start/no tach, and codes again. I disconnect the battery, try it, and it's been running since, but the key start delay, and having to turn it to a hard stop is still there and the cruise enable still shuts off
Normally with a 10 year old car I'd start shopping and trade it in, but she loves it, it's otherwise in very good shape, like a couple year old car, and there's nothing reasonably priced right now. So I'd really like to fix it.
Ideas?
