Woody
Woody GRM+ Memberand MegaDork
5/26/14 6:45 a.m.
I'm sure that there's nothing too tricky about these things. Any reason not to get the one from Harbor Freight?
http://www.harborfreight.com/5-gallon-oil-drain-dolly-90582.html
Dusterbd13
Dusterbd13 Dork
5/26/14 7:34 a.m.
ive been using that one at my dads place for years. had to rebuild the caster mounts once (failed on the steel tube, dont remember why. probably dropped the lift on it) and re-weld the nut for the wing nut.
they work.
Donebrokeit
Donebrokeit Dork
5/26/14 8:01 a.m.
Co-worker has one, same issue the casters failed. After that no issues.
Woody
5/26/14 8:16 a.m.
Wow. Caster failure wasn't what I was expecting.
Woody
5/26/14 11:17 a.m.
I just picked one up, in spite of the fact that it's surprisingly flimsy, even for a Harbor Freight product. Even the display model had the above mentioned caster mount failure, but it was still $100 cheaper than anything else that I could find and I wanted one today. I'll reinforce it as needed.
Dusterbd13
Dusterbd13 Dork
5/26/14 11:26 a.m.
mine has some angle iron from an old bedframe tacked on to reinforce it. it works, and its cheap.
dropstep
dropstep New Reader
5/26/14 12:47 p.m.
We use the cheap one from orielly's, the harbor frieght one started leaking oil at the welds really quickly.
iIPbv11LdXHjbhOCfGIbnHZ7lzPQ9WC905XeqPPEJ0Jz5xSk14yPDRVnoQoTMg29
