ross2004
ross2004 New Reader
7/15/14 8:53 a.m.
Since Ricky at the Holley tech department is of no help (did you know wideband air/fuel meters are only useful for EFI, not carbs? ) I turn to you as I'm out of ideas (and jets).
Background: car is an E30 with a Ford 302, Holley 600 cfm double pumper on top. I had the car at VIR over the weekend and am still fighting a rich condition at WOT.
Stock jetting is 66 primaries 76 secondaries. That had me with an air/fuel ratio in the mid 9's. I worked my way down to 60/61 and was able to get a it in the 10.9-11.1 range, while picking up considerable power. At that point I was using the smallest jets I had. Part throttle and idle values are perfect, and throttle response is great. I am using squirters with the brass nozzle extensions, and I'm wondering if I'm getting fuel pullover from them?
Ranger50
Ranger50 PowerDork
7/15/14 9:31 a.m.
What kind of timing are you running?
The squirters should have a number on them, that is their size.
DavidinDurango
DavidinDurango Reader
7/15/14 9:33 a.m.
My experience? Don't mess with the main jets. What air bleeds are you running? or do you even have changeable air bleeds? Vacuum secondaries or mechanical?
Air bleeds: less chance of burning your car down, less mess, easier to access.
Mains are usually in the 70-74 range with proper air bleeds.
That's my guess anyway . . . .
ross2004
ross2004 New Reader
7/15/14 9:33 a.m.
34* total advance, all in at about 2500 RPM. Squirters are 25 front, 27 rear- both have the nozzle extensions.
ross2004
ross2004 New Reader
7/15/14 9:34 a.m.
DavidinDurango wrote: My experience? Don't mess with the main jets. What air bleeds are you running? or do you even have changeable air bleeds? Vacuum secondaries or mechanical? Air bleeds: less chance of burning your car down, less mess, easier to access. Mains are usually in the 70-74 range with proper air bleeds. That's my guess anyway . . . .
Carb has fixed air bleeds, and mechanical secondaries. Thanks.
Ranger50
Ranger50 PowerDork
7/15/14 9:56 a.m.
What is your vacuum readings? I just wondering if the power valve is staying open all the time.
As to the timing what is the initial at?
ross2004
ross2004 New Reader
7/15/14 10:05 a.m.
12" vacuum at idle, with a 6.5" PV. If the PV was open all the time it wouldn't it flood out the idle and part throttle? I'm right in the 14's for air/fuel all the way up to about 1/2 throttle.
Initial timing is around 10*.
ubctQCkPDXG9IgSltcI4RUuoTpmbfvymVA5wnbUHp8FdyezwaZdJHNUWaypYGU5m
