Ranger50
Ranger50 UltraDork
10/30/12 12:51 p.m.
It's on now!!
http://youtu.be/gAl3UvngjDM
http://www.fordracingparts.com/sema/
N Sperlo
N Sperlo PowerDork
10/30/12 12:55 p.m.
My oh my.
... BOOINGGGGG!
Javelin
10/30/12 1:08 p.m.
Uuuuuueeeueuruerrrf!
And the NHRA is funny about rules and turbos, so this thing could absolutely dominate until they get someone to re-write the rules who wasn't racing in nineteen diggity-two.
Teh E36 M3
Teh E36 M3 Dork
10/30/12 1:15 p.m.
So I just went to the Ford Racing website. They have a CARB certified 750 hp bolt on supercharger kit for the mustang for $6595. Holy E36 M3balls.
alfadriver
alfadriver PowerDork
10/30/12 1:15 p.m.
So that kind of racing is really that popular? didn't know that.
I guess with the number of magazines dedicated to that, it should not surprise me...
tuna55
tuna55 UberDork
10/30/12 1:19 p.m.
Javelin wrote: Uuuuuueeeueuruerrrf! And the NHRA is funny about rules and turbos, so this thing could absolutely *dominate* until they get someone to re-write the rules who wasn't racing in nineteen diggity-two.
Yeah, they don't understand rules. Look what they've already done to the turbos in pro mod, and look what they've done with harley. Great racing, crappy rules. I hope the program goes far, it's neat watching OEMs produce stuff like this.
singleslammer
singleslammer HalfDork
10/30/12 1:28 p.m.
In reply to Teh E36 M3:
I want to say this is an upgrade as the 525 hp kit is $7500
pinchvalve
pinchvalve UltimaDork
10/30/12 1:30 p.m.
Should be the standard motor in all FoMoCo products.
z31maniac
z31maniac PowerDork
10/30/12 1:43 p.m.
Teh E36 M3 wrote: So I just went to the Ford Racing website. They have a *CARB certified* 750 hp bolt on supercharger kit for the mustang for $6595. Holy E36 M3balls.
As mentioned, it's an upgrade, but I believe the 525hp kit for the GT Mustangs don't even void the warranty.
But apparently the new 5.0 motor with a long-tubes, full exhaust, intake and tune will make 430whp!
Alan Cesar
Alan Cesar Associate Editor
10/30/12 1:58 p.m.
aussiesmg
aussiesmg UltimaDork
10/30/12 2:09 p.m.
Whistles, here ZR1, here boy
oldeskewltoy
oldeskewltoy Dork
10/30/12 2:15 p.m.
I LOVE the engineering to make CARB legit 600+hp engines...
Slyp_Dawg
Slyp_Dawg GRM+ Memberand HalfDork
10/30/12 3:59 p.m.
Wonder how long until someone here shoehorns one into a Miata or a RX7?
Javelin
10/30/12 4:01 p.m.
Slyp_Dawg wrote: Wonder how long until someone here shoehorns one into a Miata or a RX7?
Never. The 5.4/5.8 is physically wider than the front subframe rails on both cars. You would need either a fully custom tubular front end with a different suspension, or prop the motor up out of the engine bay like those dorky diecast cars.
carguy123
carguy123 PowerDork
10/30/12 5:10 p.m.
Well once they introduced the TT Ecoboost engine we said it was only time till it was stuck onto the V8.
And Javelin this is the 5.0 not the 5.4. The block is lower on this which makes the width narrower. Not narrow mind you, but narrower than the 5.4/5.8
Streetwiseguy SuperDork
10/30/12 6:34 p.m.
The Ford 4 cam motors are massive. I had one out last spring, and it. was. huge.
KATYB
KATYB Dork
10/30/12 7:26 p.m.
from what ive heard the new 4 cam is actually narrower than the old modular
BoostedBrandon
BoostedBrandon Dork
10/30/12 8:43 p.m.
Well, he did say shoehorn.
carguy123
carguy123 PowerDork
10/30/12 8:45 p.m.
I've had them out sitting side by side and yes the OHC has wider heads than the old 302. The Cobra kits had a lot of troubles fitting it in there initially but you'll notice they fit in them now. It wasn't all that big an issue once the desire was there.
Where there's a will, there's a way.
But I want the ecoboost V6 they show
365 Horsepower @ 5,000 RPM
420 lb. ft. of torque @ 2,500 RPM
All-aluminum construction
10.0:1 compression ratio
Dual overhead camshafts with variable camshaft timing
High Pressure Direct Fuel Injection
Regular Unleaded Fuel recommended
Lightweight die-cast aluminum block with six-bolt press-fit main bearing caps with piston-cooling jets
Fully counterweighted forged steel crankshaft
High-strength forged powder metal connecting rods with floating pins
Lightweight aluminum high-strength pistons with low-friction skirt coating
Tuned composite upper and lower intake manifold
Dual water cooled Honeywell/Garrett GT15 turbochargers
6 quart die-cast aluminum deep sump oil pan
Engine weight is 417 lbs. (without accessory drive)
Engine Kit Includes:
    Starter
    Alternator
    Front accessory drive and belt
    Air cleaner assembly and ducting
    Flexplate/flywheel
singleslammer
10/30/12 8:52 p.m.
In reply to carguy123:
Interesting. That seems a bit heavy though. Also, will it come with hot rod style engine management or will that be another 2k like on the v8?
carguy123
carguy123 PowerDork
10/30/12 9:55 p.m.
singleslammer wrote: In reply to carguy123: Interesting. That seems a bit heavy though. Also, will it come with hot rod style engine management or will that be another 2k like on the v8?
1) who says it's heavy? How often do we get a chance to have valid weight numbers? I keep seeing 360 or more for straight 4's
2) what I have heard is that they do have the engine management.
bravenrace
bravenrace PowerDork
10/31/12 6:01 a.m.
A 5.0 pushrod crate long block with aluminum heads is 298 lbs. Ready to bolt in it's about 380 lbs.
Ranger50
Ranger50 UltraDork
10/31/12 6:29 a.m.
bravenrace wrote: In reply to carguy123: A 5.0 pushrod crate long block with aluminum heads is 298 lbs. Ready to bolt in it's about 380 lbs.
Source please? The best I have seen is about 450#. Add in a ~100# C4 trans, 25# converter...... That makes one light drivetrain.
bravenrace
10/31/12 7:56 a.m.
In reply to Ranger50:
The source is me. I weighed mine on a certified scale at work. That did not include any accessories added to it, like the alternator, power steering pump, starter. It did include an aluminum intake, aluminum water pump, distributor and stock flywheel.
carguy123
carguy123 PowerDork
10/31/12 8:47 a.m.
I no longer have the pictures to prove it, but the 351 I had in the Cobra weighed in excess of 500#. It had alum heads and intake manifold and carb, but didn't have the alternator, clutch, or power steering pump.
IIRC it was 560#, but in any case it was over 500#.
It put out a little more horsepower than the V6 in question but not as much torque and it definitely didn't have as wide a power band as the V6.
TXhvOwKwswyavzDxvoC1A9X8Ra7dbpuorsfMQS7kiNvULfvKl0R2NXjg2c2Sxqw7
