93EXCivic
93EXCivic SuperDork
2/5/11 6:37 p.m.
Ok so I have spent all night on dseries.org and playing with this compression calculator. http://www.zealautowerks.com/dseries.html What compression ratio can be run on 93 octane?
DaveEstey
DaveEstey HalfDork
2/5/11 7:31 p.m.
depends on the tune.
93EXCivic
93EXCivic SuperDork
2/5/11 7:39 p.m.
So would ~11:1 with Bisimoto engineering Level 2 camshaft and a tuned Hondata S300 be do able on 93 octane provided the tune was done right and for that matter in anyway streetable?
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
2/5/11 8:10 p.m.
^Easily. I've run 13.5:1 on 93 octane. Had to give up some timing, but that was also before E85 was readily available.
kb58
kb58 Reader
2/5/11 11:09 p.m.
cams make a big difference. If the ramps overlap, they let some of the compressing mixture back out of the cylinder, effectively lower the compression ratio, so a "13:1" engine might actually be an "11:1" with a race cam.
iceracer
iceracer Dork
2/6/11 10:00 a.m.
Fiesta has 11:1 on 87.
93EXCivic
93EXCivic SuperDork
2/6/11 10:04 a.m.
Well hell I might go with PM3 pistons and ~12:1
92CelicaHalfTrac
2/6/11 12:35 p.m.
I would... or even more, honestly.
Depends what head and if you're milling or not.
11:1 isn't even touching the limits of pump gas. Later Celica GTSs were like... 12.5:1 stock.
DaveEstey
DaveEstey HalfDork
2/6/11 1:44 p.m.
In reply to 92CelicaHalfTrac:
2ZZ-GE is 11.1:1
92CelicaHalfTrac
2/6/11 1:46 p.m.
DaveEstey wrote: In reply to 92CelicaHalfTrac: 2ZZ-GE is 11.1:1
My bad, i fat-fingered. Not 12.5:1, but it's 11.5:1.
DaveEstey
DaveEstey HalfDork
2/6/11 1:48 p.m.
It'd be awesome if Toyota brought a 12:1 engine over to the states.
ss
ss New Reader
2/6/11 3:15 p.m.
12-1 is pump friendly. I have 10 hard years of flogging on my built b18c. Go for it
92CelicaHalfTrac
2/7/11 8:23 a.m.
DaveEstey wrote: It'd be awesome if Toyota brought a 12:1 engine over to the states.
I'd love to see a revised 2grfse w/ 12:1 or higher compression. I bet it would put out fairly insane power.
93EXCivic
93EXCivic SuperDork
2/7/11 9:57 a.m.
It would be on a Z6 with PM3 pistons, stock head gasket and .020" milled head. That would give me a compression ratio of 12.39:1.
HFJUZwbhhEJtH6s0RmJTVIdRDNGHUKcL3vFSInqG0avfxqHdgwZlmBzJuCmjJqJt
