ditchdigger
ditchdigger Dork
10/19/11 10:10 a.m.
My motor sans turbo, downpipe and muffler weighs under 120. The transaxle is 70lbs tops. I figure 225 complete and full of coolant.
The whole car weighs in around 1400lbs
carguy123
carguy123 SuperDork
10/19/11 10:32 a.m.
And the Goldwing is replacing your motor with one that produces a lot more HP.
The last dyno I saw of a Goldwing was almost identical to that of a Miata.
FlightService
FlightService Dork
10/19/11 8:19 p.m.
How about a Rocket engine in a Triumph Spitfire? Triumph on Triumph goodness there
ransom
ransom GRM+ Memberand HalfDork
10/19/11 8:42 p.m.
In reply to FlightService:
That was the first thing I was thinking with the Rocket III. I was a bit bummed that I couldn't do it in Street Mod under the umbrella of Triumph Car, Triumph Engine. Turns out they specify a car engine
Would've been awesome, though. Sequential gearbox, 140 hp, 150 ft-lb torque (at 2500 RPM!) stock. That'd move a Spitfire right along. And then there are the forced induction kits... I do wonder how tall that engine is, though. And what it weighs...
How many other like-brand motorcycle engine/car body swaps could there be? Hayabusa-powered Swift under the Suzuki banner? Blackbird-powered Honda N600?
DaewooOfDeath
DaewooOfDeath HalfDork
10/19/11 11:05 p.m.
Yamaha R1 powered SHO?
ransom
10/19/11 11:07 p.m.
In reply to DaewooOfDeath:
One at each end?
DaewooOfDeath
10/20/11 1:33 a.m.
Ultra complicated way to make the same power as stock, I love it!
hobiercr
hobiercr GRM+ Memberand SuperDork
4/22/21 7:47 p.m.
4/23/21 6:33 a.m.
Engines from BMW K-1200LTs have reverse in the transmission, where early GWs used the starter motor spinning backward.  Weird but VERY helpful when you drop the nose off the edge of the parking lot.  I think both have about the same low center of gravity.
Have you looked on ebay?
Also poke around Naked Gold Wings (NGW).  They're a lot like us only with Wings.
Goldwing inside.
Trent
Trent PowerDork
4/23/21 8:57 a.m.
10 years after this thread an absolute legend in New Zealand has gone full Allan Milyard and is undertaking this idea in the best way possible including deleting the goldwing transmission and associated gears and shafts from the flat 6, machining the case down and mating to a transmission in the back of a Hilman imp.
https://forum.retro-rides.org/thread/202566/hillman-imp-project-hondas-flat?page=31
tmz1JaLeMlh16XQv7Xgw9jzcVht3koNkeTsu1Nxrtv6zc4avYLKrN1p7f9KRG3ww
