johnp2
johnp2 New Reader
2/21/11 6:33 p.m.
Hi guys, I'm an avid reader and listener of this site yet rarely post. But I've recently come across a problem with my sister's Honda and was hoping some of you experts could lead me in the right direction.
Background: 1997 Honda accord f22 non vtec had a cooling issue 170k miles automatic
So what i did was remove the timing belts, and the water pump. I found both to be in very good shape so i reinstalled. this work turned up bad radiator(holes), cv axle, brakes, and serpentine belts. All of this work was done. Car started ran great, no issues the day after the work was done. Today I'm told its not starting. It has fuel, and spark, tries to catch but just turns over. I'm thinking slipped timing? Ill dive into the timing belts on Thursday unless anyone can offer wisdom?
Thanks in advance guys.
John
dculberson
dculberson Reader
2/21/11 7:23 p.m.
Only thing I can think of is the F22 has a problem with the ignitor / ignition module getting weak and going out. It'll get flakey then eventually stop working altogether. Make sure the spark is strong enough.
TreoWayne
TreoWayne New Reader
2/22/11 1:45 p.m.
If a Honda will turn over but won't start I would start investigating the PGM-EFI main relay. There is lots of documentation online about this.
It might not be your problem but it is still good to know.
johnp2
johnp2 New Reader
2/22/11 9:06 p.m.
I appreciate the tips, ill look into it shortly and report back.
Thanks John M.
johnp2
johnp2 New Reader
2/24/11 8:17 p.m.
Ok i have an update.
Got home today, removed the timing belt and balance belt and reinstalled after setting time. Car still wouldnt start. So i went ahead and replaced the plugs, which looked terrible. Car took a while, eventually started and put out some decent smoke for a bit, figured this was normal probably oil. Took it out for a spin ran great.
Got home tried to start and its still hard to start, meaning it turns over tries to catch idles low for a sec then dies. Try again and it idles low and eventually rises to normal idle. This happens on all starts where i wait more than ten minutes after shutdown.
Any ideas fella's.
Thanks again John
unevolved
unevolved HalfDork
2/24/11 9:43 p.m.
What do the plugs smell like?
johnp2
johnp2 New Reader
2/24/11 9:45 p.m.
smell like fuel
unevolved
unevolved HalfDork
2/24/11 11:36 p.m.
Have you checked that you're getting spark?
Merc
Merc New Reader
2/25/11 3:37 a.m.
I would check for spark too. Bad plugs usually mean bad spark wires too.
I would check # 2, 8 and 15 in diagram
<a href="Photobucket">
I would also check # 10 for rot at # 14 and 26. These usually go bad on older Hondas. Photobucket
BTW, what color smoke?
Tyler H
Tyler H GRM+ Memberand Dork
2/25/11 5:43 a.m.
If all that checks out, check the compression.
johnp2
johnp2 New Reader
2/25/11 1:42 p.m.
I am getting spark, smoke was white, im starting to suspect a head gasket issue. What raises suspicion is i notice the radiator hoses are getting stiff, as if with air when it is running.
Merc
Merc New Reader
2/25/11 1:53 p.m.
White usually means coolant is burning in the chambers. I would assume head gasket may be going out as well. Do a compression check and check you oil to make sure it's not brown.
johnp2
johnp2 New Reader
2/25/11 4:02 p.m.
Ok guys update for today. Got in this morning tried to start. Wouldnt at all. So i took my miata to work. Came home turned the key and fired up fine. I did some test driving including many stops, and it started just fine each time. Just checked all the above and all looks well. Spark plugs have some whiteness to them, and the compression reads 140, 145, 140, 150. A good sign im hoping. Strange that it would be fine today. Anyways ill keep an update. I reallly appreciate all the help everyones given so far.
Go GRM John
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
2/25/11 4:08 p.m.
Is it more likely to NOT start if the motor is warm?
CPS can and will go out on these, and it's usually exacerbated by temperatures.
johnp2
johnp2 New Reader
2/25/11 4:52 p.m.
it was kind of intermittent, and i haven't had any trouble thus far today. But it has happened both warm and cold at one point or another. I'm gonna let it sit for a few hours and see if it starts ok again, then i may take it tomorrow for a drive and go from there. Hope its not that cam sensor, expensive. That should throw a code i'm guessing. fingers crossed.
Thanks
k0lf6ZHYbCCOlnfBoI0t3NvxrDaLBlbnfkHbQlwWedhkUUZiz6IkzSI8CtwbZ7xz
