Dana has had her 2012 civic since new, it now has 152k on the clock. Hasn't had any major problems. New muffler and resonator, brakes, a battery, and a control arm have really been the only repairs that I remember.
Starting last year, I noticed it getting sluggish. First on steep hills, and now on flat land too. My initial thought was cat, but it still hasn't thrown any lights and the mileage is staying roughly the same.
I don't know the last time it's had its plugs changed. I popped the hood today to check them and couldn't find them unless they're under plastic. I'll look a little deeper tomorrow in the driveway with tools.
Now while researching if it was an interference engine or a chain vs belt engine, I found out its drive by wire, "programmable fuel injection", and has some sort of dual stage variable intake manifold (wtf?), and requires a valve adjustment every 25k. I still don't know if it's chain or belt, or interference, but I guess there isn't a butterfly that needs cleaned or anything simple like that.
Should the car be my main suspect? Does the Ivtec that "shuts off 4 valves at low rpm for economy" shut off with the eco mode button?
Basically, I've tried ye olde Italian tune up and had no luck.
It does have another issue, this one related to braking. I replaced front pads and rotors last year, about 8k miles ago. Did nothing with the rears. At 20mph, while turning, I'm getting a slight rumble from the rear passenger wheel, and at any speed the pedal feels like E36 M3. It's not going the whole way to the floor, and the fluid reservoir looks good, but it's not stopping very well. Double tap the brakes to downshift then pump them once or twice while coming to a stop. I don't think it could safely panic stop currently, and I've come very close to needing it to driving through Pittsburgh the last couple days.
My plan tomorrow is to get it onto jack stands, check the fronts are still good because front driver is squealing like a pig, then dig into the rears to see what's up with them. Maybe do a fluid change, definitely bleed them all around.
Sorry for the giant wall o text, just trying to get all the relevant information out that I can in the first post.
