bfrance101301
bfrance101301 New Reader
8/31/08 12:51 a.m.
Help!
I'm trying to get the uprights off of my '95 accord to do some suspension work. Driver's side is done, but on the passenger's side, when I try to break free the castle nut on the lower ball joint, the stud spins with the nut!!! AAARRRGGGHHH!!!!!!!!!!!!!!
I'm so close to being done with this, and at 1am CST, I'm finally giving up for the night.
Any input would be greatly appreciated!!!!!
-Ben
Apexcarver
Apexcarver SuperDork
8/31/08 1:25 a.m.
impact wrench?
i had similar with my ratchet, but the impact took it right off.
oldschoolimport
oldschoolimport New Reader
8/31/08 2:05 a.m.
get a BFH and see if you can knock the ball joint further up in the taper. if you can seat the taper, it will quit spinning.
Run_Away
Run_Away GRM+ Memberand New Reader
8/31/08 2:40 a.m.
Put a jack under the LCA and let the weight of the car seat the stud.
DMSentra
DMSentra New Reader
8/31/08 10:57 p.m.
Run_Away wrote: Put a jack under the LCA and let the weight of the car seat the stud.
+1 this idea, second choice is the impact in short bursts.
2jZsPzLy88W8NdTxQ69BtdNmsdfym31lrpFCAb8jN6lcUJVqDUNInzor65NaLnPS
