therieldeal
therieldeal Reader
3/29/19 8:14 a.m.
Alright so obviously a fast driver would be giving up a fair bit of time on the street tire. However, I would put myself more firmly in the “competent” driver category… this will only be my 3rd season of autocross.  I *might* have a chance of winning my class here and there but no way will I be competing for FTD.
So looking at this from one more angle… developing my driving skills/car control/etc. Better off with the street tire or the slick?
dr_strangeland said:
I'm not sure this is entirely accurate. I have the 245 A7 and 245 Rival mounted on the same wheel and if there's a difference, it's very minor. I could take a picture of the two next to each other the next time I swap wheels - probably Sunday.
I would say there's much more difference in compound and in tread void. Also, the Hoosiers are noticeably lighter.
I would be interested to see a photo and/or overall section width measurement comparison, if you have a chance.  I based my statement on the published tread width dimensions.  That's the same width wheel I will be running up front (reverse stagger fwd...)
dr_strangeland
dr_strangeland GRM+ Memberand New Reader
3/31/19 12:58 a.m.
I just loaded the slicks into the support vehicle. I'll make sure to take a picture tomorrow. You may be totally right about them being different, I just know I didn't have to clearance the fenders any more when I put on the slicks, and there's only a few millimeters of clearance when I put on the Rivals. They didn't look dramatically wider to me.
chada75
chada75 Reader
3/31/19 6:17 p.m.
In reply to therieldeal :
Better and more economical to improve your driving than buying softer tires.
poopshovel again
poopshovel again MegaDork
3/31/19 6:52 p.m.
z31maniac said:
If you aren't trying to win your class, I don't see the point in using more expensive, less durable tires that make your day of fun more a PITA.
If you aren’t trying to win your class, why bother showing up?
jeffpdesign
jeffpdesign GRM+ Memberand New Reader
3/31/19 6:54 p.m.
With SCCA and other groups driving on Hoosier slicks puts me in a MUCH faster class than my RE71rs.
Are you hoping to win a class, TTOD? Or simply go as fast as possible?
Practical answer is RE71r. Faster times? Hoosier. Winning class? That gets complicated.
Patientzero
Patientzero New Reader
4/1/19 6:44 a.m.
TRUTH BOMB!!  I don't understand this "Autocross is supposed to be fun" argument.  It's Racing!  I'm spending thousands of dollars on a car and paying an entry fee.  I'm showing up to win.
dr_strangeland
4/1/19 3:19 p.m.
Can't it be both?
I like to win. I also like to have fun. I don't take autocross nearly as seriously now that I hillclimb, and the experience has improved infinitely for me, and my times are even faster than before. I still show up with a well-prepared car, I'm just not stressing about making every single event or what my championship points look like.
Anyway. The tires.
Yes, the A7 is more square on the wheel. It looks maybe 10mm wider. It's not dramatically wider. It is definitely several pounds lighter.
The Rivals have a narrow window where they will be almost as fast as the slick, then they will fall off and become greasy and unpredictable. I feel like the RS3 was the only 200tw that I've had that really liked to take heat, and they are bricks when the temperature dropped. I was doing data entry during the second heat, and everyone on street tires was fastest on their second or third run. Times just started going back up. Nobody was really spraying because I guess we all expect it to be colder in March.
4/1/19 3:23 p.m.
Uhhh, because it's fun either way?
4/1/19 3:27 p.m.
If it's not fun there is ZERO reason to do it.  It is, after all, A HOBBY, no matter how good you are at it.  Unless you are on a 10-year plan towards an F1 seat, in which case if you have a valid driver's license, you are already 5 years too late.
Winning is better than losing without question.  But it is not the only thing, Vince Lombardi be damned.
docwyte
docwyte UltraDork
4/1/19 5:24 p.m.
Everyone likes to win.  However, you can have fun even if you don't win.  This is an amateur hobby, McLaren isn't going to knock on your door just because you win your class.  Is being all serious and competitive, spending tons of money and potentially wrecking a good time worth it for a plastic gold trophy or a plaque?
I go to track days and auto-x to have a good time and see my friends.  If I happen to do well, that's just a bonus.
dr_strangeland
4/2/19 12:18 a.m.
therieldeal said:
Driving style-wise, I set the car up loose and tend to “toss” it into turns, to get it to rotate ASAP & get back on the gas (high power fwd). Wondering which tire is going to be more forgiving in this situation… I’m thinking the BFG, as I’ve heard the A7 requires “precision”.
This thread is turning into a religious discussion, which seems to happen with this particular type of question ('which tire is fastest?' turns into 'why do you race?' turns into 'what are your life goals and philosophy and how does your tire choice reflect how you live your life') and I'd like to address some of these more specific questions from OP.
Which tire is going to be more forgiving of an aggressive driving style?
The Hoosier, in my personal experience. The levels of absolute grip are significantly higher, so for any given corner, you can throw the car harder into the corner and not lose the tail, everything else being equal. I also have found that the transition from static to kinetic friction is more progressive with the slick, even if the transition happens more quickly than the Rivals. Sure, the Rivals might tolerate a slightly higher slip angle before giving up and sliding, but when they do give up and slide it happens quickly and the difference in traction between gripping and sliding is more dramatic. The car will rotate quickly when the Rivals start to slide (especially if they are hot and at the limits of their temperature range, ie, when they are working their best). When the Hoosiers start to slide, the drop-off in grip is less steep, and the car will rotate more slowly, making tucking it back in line fairly simple. It's as if the lateral grip of the slicks is like a gradual peak, whereas a 200tw that's really hot and sticky has a peak grip and then a sudden drop-off. The local drivers that are really fast on 'street' tires are fantastic at finding this peak and then not going past it.
I think the Hoosiers could actually cover up issues with your driving that the Rivals might not tolerate as well.
I find them to be very forgiving, but I also don't ignore what they are telling me. Compared to a typical street tire that will start making noise, complaining more and more as slip angle increases, and then finally giving up and sliding, a slick will quietly reach it's limit, grip will start to drop off, and then it will be sliding without any audible feedback or tread squirm or other indications. I suppose this could be an issue for some drivers. Personally, I like to drive with my butt rather than my head, and the Hoosiers communicate far better to me through the chassis and steering than any street tire.
'Street' tire wins this one hands down, unless the skill you're developing is specifically driving on slicks, which is where I find myself now. If you're trying to improve your car control and get faster, seat time matters more than anything, and pushing the limits and exceeding them on a regular basis to become better at handling the car beyond it's limits. Because the limits of the slick are so high, and the costs of running them so significant, pushing past their limits safely might be more of a challenge and every time you do so, you are wasting precious grip you have spent a lot of money on. It doesn't make sense.
Of course these are all my opinions, and as such aren't worth a great deal. However, I'm also trying to learn better skills and maximize my bang for the buck, so I'm in much the same boat. Given that both sets of tires are readily available to me, I don't run the Hoosier unless I'm really trying to be competitive.
Patientzero
4/2/19 6:34 a.m.
Now you've crossed the line.
Harvey
Harvey GRM+ Memberand SuperDork
4/2/19 2:39 p.m.
The Hoosiers are way faster than the Rivals. If your class allows Hoosiers then you should run Hoosiers. If running Hoosiers puts you into a different class then IMO stick with streets for convenience.
Just go look at any results from a national level event. Ignoring 2018 because a river ran through the event if you look at the 2017 Solo Nationals results and compare A Street with Super Street R, you've basically got an apples to apples comparison in terms of cars, one set running on streets (in most cases the Rival S) the other running Hoosiers. In both cases the competitors are running on tires that are at the peak of their condition. The Hoosiers lead the Rivals by a second or more on a 60 second course. That's a lot.
dr_strangeland
4/2/19 3:56 p.m.
They were good for a bit more than two seconds on a two minute hill, with no other changes to the car. I think the difference could be even greater than that, but I only got half the runs I was supposed to on the slicks.
What really struck me was the difference in consistency. My run times on the Rivals during the first part of the season often showed big improvements between two runs, and then a small improvement or a slightly slower time for the next run. It was hard to recover from minor mistakes and pushing to make up time would just make things worse.
The first session I put Hoosiers on the car, with no prior experience driving on a slick, my run times were:
2:19.1s
2:16.0s
2:13.4s
2:11.2s
That's a delta time of 3, 2.6, and 2.1 seconds respectively. I don't think I could click off that consistent of a progression with the Rivals if I tried a hundred times.
Matt Huffman
Matt Huffman New Reader
11/6/19 7:31 a.m.
2:19.1s
2:16.0s
2:13.4s
2:11.2s
Dr. Stangeland, thanks for sharing your experience.  i just started SCCA Hillclimbs this season after 10 years of autocross, HPDE, and time trials / time attack.  Hillclimb is a blast!  There's nothing like it.
I ran RE71Rs last season, but they were mid-2017 old stock when i received them "new".  i was not thrilled with their performance, and by the end of the season (8 hillclimbs and 10 autocrosses and 2 circuitcross / time attack) they took forever to heat up and didn't have much grip when they did.  Did your Hoosier A7s maintain the same warm-up time and grip throughout the season?  I was leaning more towards the BFG R1S; have you run both the A7 and the R1S for comparison?
Matt Huffman
11/9/19 10:02 a.m.
therieldeal said:
Let’s talk tires! Specifically… who’s run both Hoosier A7’s and the Rival S 1.5 on the same car & can comment on differences? I’m back on the fence trying to decide which I want to run this year. Obviously the Rival is easier to live with as I can just leave them on the car all season. However the A7 has the potential to be significantly faster… how much faster? Driving style-wise, I set the car up loose and tend to “toss” it into turns, to get it to rotate ASAP & get back on the gas (high power fwd). Wondering which tire is going to be more forgiving in this situation… I’m thinking the BFG, as I’ve heard the A7 requires “precision”.
Sam strano runs a vette and has two videos with times for both these tires. Search on YouTube
poopshovel again
11/10/19 4:01 a.m.
I don't know why I said what I said 8 months ago. Perhaps just being a grouchy dick. Sorry. I've run my street car on street tires plenty of times for fun.
aLtgpGviwAoOSYIStqeWqTKVbVIipI6fMlhY6VPj8PEo1lnolNl3bEfiZCqMrFjc
