chandlerGTi
chandlerGTi HalfDork
9/8/12 7:03 p.m.
JKleiner wrote:
SilverFleet wrote: ...you could stuff a 360 in there, as it should fit no problem.
Be aware that while a 360 will bolt in where a 318 was the balance is different so if you do not also use the matching flexplate/converter/harmonic balancer combination you'll have a 4 wheeled paint shaker! Good luck with your recovery and project Jeff
This is true, external dampened on the 360s.
Vigo
Vigo SuperDork
9/8/12 7:38 p.m.
I have an 'in progress' dakota 360 swap going (magnum). Some later 360s had a balanced flexplate/flywheel but my swap donor had a balanced converter.
Since im keeping the a500 i had to weld some balance weights to my existing converter with a paper template. Mopar sells a kit to do this that runs about $20.
chandlerGTi
9/8/12 7:41 p.m.
Vigo wrote: I have an 'in progress' dakota 360 swap going (magnum). Some later 360s had a balanced flexplate/flywheel but my swap donor had a balanced converter. Since im keeping the a500 i had to weld some balance weights to my existing converter with a paper template. Mopar sells a kit to do this that runs about $20.
Good to know!
Lesley
Lesley PowerDork
9/8/12 9:59 p.m.
Sounds like a fun project. Mine's a later Dakota, so most of the elements are different. I took a 97 V6 Sport and decided to make it into an R/T killer. Bought a 5.9 from a wrecked Grand Cherokee, installed a windage tray, lumpy cam, 1.6 roller rockers, Mopar 1 piece aluminum intake manifold, larger throttle body and headers. Tranny is a 45RE with kevlar bands and clutch plates, and a transgo shift kit. Swapped the 3:55 rear end for 3:92s and a locker. It goes pretty good, only real problem was finding a computer that would talk to both engine and gauges, since a 5.9 wasn't available until 1998. Ended up using one for a 97 with 318, and having it reflashed.
Rob_Mopar
Rob_Mopar Dork
9/9/12 7:48 a.m.
M030 wrote: Anbiss know The Wheel Volt pattern measurement? Truck Nerds Dome Cragars pr Ansen style Spottes mags( think Starallüren hutch Torino) bur i wanr find a cheap Set of Used ones. New ones are Kind of pricey
Ranger50 wrote: 5x4.5. 5 lug is the same as the Fords.
Your '91 was the first year for the 6-lug wheels. They are 6x4.5" Dakota and early Viper only. To go to 5 lug you'll need '87-90 Dak rotors up front and same years rear axles and drums. If junkyarding for the rear axles, make sure they are coming out of an 8 1/4 rear, not the light duty 7 1/4.
The axles are a C-clip design. You'll need to pop the diff cover off to get them out.
chandlerGTi
9/9/12 10:10 a.m.
Your '91 was the first year for the 6-lug wheels. They are 6x4.5" Dakota and early Viper only. To go to 5 lug you'll need '87-90 Dak rotors up front and same years rear axles and drums. If junkyarding for the rear axles, make sure they are coming out of an 8 1/4 rear, not the light duty 7 1/4. The axles are a C-clip design. You'll need to pop the diff cover off to get them out.
And although I tried the viper wheels do not fit well under a Dakota.
M030
M030 HalfDork
9/24/12 7:03 a.m.
I bought an intake & Qudrabog from an old Diplomat & I'm going to take the huge Edelbrock off of it. Huge edelbrock is going on the LT1 Chrvy I'm putting in my 944
Ranger50
Ranger50 UltraDork
9/24/12 7:29 a.m.
chandlerGTi wrote: And although I tried the viper wheels do not fit well under a Dakota.
The Viper wheels look like they fit just fine....
Rob_Mopar
Rob_Mopar Dork
9/24/12 8:35 a.m.
M030 wrote: I bought an intake & Qudrabog from an old Diplomat & I'm going to take the huge Edelbrock off of it. Huge edelbrock is going on the LT1 Chrvy I'm putting in my 944
That should work. Make sure your trans kick-down linkage is connected. The lever on the trans should bottom out when at full throttle.
u0Kg1QFWJXUJJhBB2lXfS0UiFl8au7SoaqmzbL0edGQz03OAAiWiPs3c8o4DbqqZ
